588,383 active members*
4,785 visitors online*
Thread: okuma lathe
    Sep 2010
    okuma lathe
    trying to get my LC-20 lathe spindle to orient, wont work with just M19 or a C callout, it looks for spindle orient spec.? OSP5000L-G control, any suggestions greatly appreciated, thanks
    Feb 2009
    6028
    Was an option, and usually only with live tooling. Not real common on those old machines.
    Mar 2009
    1982
    is it with milling function?
    some alarm or error message?
    Apr 2006
    825
    Hey Al,
    Read the original post!
    kwhite2 stated that it was looking for "spindle orient spec"!
    i.e. that is what the alarm message is.
    Sorry kwhite, but if your machine is asking for a spec code then you do not have that option available.
    Is your machine an LC20M? i.e. does it have the live spindle option on turret A?
    If your machine does have the milling option then there are other problems.
    For future reference, please state the full alarm code string as displayed on screen, it does help lots.
    Cheers
    Brian.
    Nov 2010
    Could be its an indexer; will stop and lock at 5 degree angles for example, you need to find out the spec of the machine and OSP type to give us a clue.
  1. G71 Threading for Okuma Lathe
    By pedgette in forum G-Code Programing
    Last Post: 04-12-2020, 08:00 PM
  2. Okuma LB 12 CNC Lathe
    By rajappa in forum Okuma
    Last Post: 10-09-2014, 12:19 AM
  3. okuma lathe
    By kantaras in forum Mastercam
    Last Post: 11-17-2009, 12:24 AM
  4. Okuma lathe with Mastercam
    By LT1TRUCK in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-05-2008, 10:37 PM
  5. 2-1/2 External NPT on Okuma Lathe
    By jdr1961 in forum G-Code Programing
    Last Post: 02-15-2007, 04:12 AM
