586,700 active members*
3,134 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal Rotary Controller
    Feb 2007
    12
    I have a troyke rotary table that came with a standalone servo controller. I am trying to interface it with a Hurco VMC. My problem is that the finish signal from the control box is a pulse and my machine needs the relay to remain N/C. I couldnt find a parameter to change this in the menu so I opened up the box figuring there may be some jumpers to adjust this. I dont see anything that is obvious. But I did see that all the boards inside are marked Fadal Enginieering. So I am assuming that this controller was manufactured by Fadal for Troyke.
    Does anybody have experience with these and/or a operators manual?
    24223
    Normally the FINish signal IS a pulse, does the relay pulse now but the wrong logic?
    If so does it have a N/C contact you can switch it to if it is presently N/O?
    Al.
    Albert E.
    Feb 2007
    12
    The relay itself is soldered on the board and I dont see anything that looks like a jumper to switch it to N/C. There has to be a way to do this but without a manual Im kind of lost.
  1. Replies: 1
    Last Post: 10-12-2011, 11:05 PM
  2. Fadal 4th Axis Rotary /w Thru Hole ?
    By northwestfab in forum Fadal
    Last Post: 12-15-2007, 04:16 AM
  3. Need Rotary Post For Fadal
    By Cappy in forum GibbsCAM
    Last Post: 01-17-2007, 02:43 PM
  4. Replies: 4
    Last Post: 03-02-2006, 04:46 AM
