I'm about to embark on making several hundred coasters from hardwood.. They want their logo engraved in them...
The coasters will be 3/8" thick.. The idea is that I will pre-finish them, apply contact paper to them (like that on acrylic), carve/engrave them, spray dark brown or black paint, then peel the paper off and clear coat them... finally adding three cork dots on the bottom of each...
Each coaster will be 3.5" round.. So the Logo will be approximately 2.75-3" wide
This is the logo they sent me..
http://www.mountaincraftworks.com/pix/bearcreeklogo.jpg
I am going to make some changes with their blessings, including changing the shape of the mountain range to match lassen range, and using one of these bear vector images to be purchased from Vector Art.com.. They are interested in 52824 and 33543, especially the 543 one...
http://www.mountaincraftworks.com/pix/bearimages.jpg
Originally, I was going to V carve them, but I'm not sure that would be best due to the thickness of the coasters, and moisture collection.. So I was thinking about engraving them by creating a 'flat depression' where the black parts are, leaving the white areas untouched.. maybe 1/32-1/16" deep..
I was looking at getting one of the Amana In-groove bits for this.. But I'm not sure if that is necessary or which blade to buy.. I'd kinda like to save some money and put it towards Cut 3D and some vector Art 3D files...
Bits I currently have that might be useful are a 1/8" single flute strait bit, a 3/16" double flute strait bit, a 1/4" two flute mortising bit, a couple 1/4" upspirals, a 90 degree carbide tipped V bit, a 60 degree Amana insert bit V bit, a MCHS 45 degree carbide tipped V bit, a couple 1/8" bull nose bits, etc..
If there's a less expensive alternative to the In-Groove bit that would be great...
Basically I need suggestions.. they need some of them (hoping to get 100 made) by weekend after next, so I need to order a bit as soon as possible seeing as it will take a few days to ship...
Also looking for comments on my 'methods' and suggestions for finish materials... Will be making these out of sapele, poplar, and alder...
Mark
