587,751 active members*
3,798 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > How do I know if I have sync tapping?
Hybrid View
    Sep 2011
    I have an older MC4VA with an OSP5000M-G controller. How do I know if I have rigid or sync tapping cycle? I have tried G284 but it errors on that. I am trying to run a large tap in and out twice and its off pitch on the second cycle...
    Dec 2008
    3136
    Our old 4VA could not rigid tap
    We always had to use floating holders
    & program the feed in units per minute, it couldn't do a G95
    PS -- we couldn't even do ramping on an arc ( ie helix cutting a bore had to be done by point to point )
    24220
    If you don't have an encoder on the final spindle, then that points to not having the option.
    Al.
    Albert E.
  1. Sync. Spindle and A Axis
    By itstom in forum Haas Mills
    Last Post: 07-07-2011, 06:52 PM
  2. X axis out of sync
    By Arif Fayyaz in forum Controller & Computer Solutions
    Last Post: 03-28-2011, 12:26 PM
  3. Plasma Cam 98-z cut sync problems???
    By ziptie007 in forum PlasmaCam
    Last Post: 02-12-2009, 03:07 AM
  4. Sync Spindles Help
    By chucker in forum Fanuc
    Last Post: 11-26-2008, 06:12 PM
