603,818 active members*
3,978 visitors online*
    1880
    X axis backlash
    My Sl-30 needs a new Ball-screw and nut there is backlash confirmed at the nut. I currently don't have the money to replace it.
    So temporarily I'd like to adjust the backlash number in the machine parameter. Anyone know how many encoder counts to a .0001" of an inch, and in which direction to modify it?
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Jul 2005
    12177
    Have a look at Parameter 266. Somewhere down the screen you should se X RATIO (STEPS/UNIT) this is steps per inch so you can figure out the steps for 0.0001". I don't know which way to change the backlash Parameter but you can easily get that by a few trials.
    1880
    Thanks man! I'll check into that
    thanks
    Michael T.
    1880
    Well I got it set to what it needs to be. Don't know that it will help as the turret weight makes it take the slack up in both directions unless you push on the turret by hand.
    So If I'm doing something tight probably will depend on the size cut I use for finishing, and if that cut is enough to push the added weight.
    Lame, well I'll have to get more work (ya not like that's hard enough in this economy)
    thanks
    Michael T.
  1. Backlash Nut On Z Axis?
    By Imacman in forum Canadian Club House
    Last Post: 07-05-2010, 11:45 AM
  2. X axis backlash SX3
    By kenealym in forum Syil Products
    Last Post: 04-28-2010, 03:30 AM
  3. X2 Backlash Y axis
    By BrassBuilder in forum Benchtop Machines
    Last Post: 01-28-2008, 04:45 PM
  4. Backlash C-axis
    By M-man in forum Daewoo/Doosan
    Last Post: 05-10-2007, 04:40 AM
  5. Z axis backlash
    By maxxdog21 in forum Benchtop Machines
    Last Post: 03-02-2005, 05:12 AM
