603,832 active members*
4,953 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > encoder wiring channel A and channel B
    Apr 2004
    79
    I have 320 drives I am wiring up. I have shielded 2 pair wire for the encoders. Black and red are shielded together and white and green are shielded together. do I wire enc - and chanel B in the same pair or enc - and channel A? thanks for your help
    24260
    Black & red, + & Com.
    White & Green, A-B.
    Al.
    Albert E.
    Apr 2004
    136
    encoder wiring using twisted pair
    I respectfully disagree with Al_The_Man.
    Putting a differential signal on a twisted pair is desirable,
    but in this case, encoder phase A and phase B are NOT
    a differential signal.
    A and B are quadrature signals, and as such they should
    be prevented from having cross talk with each other.
    Putting two single ended (non-differential) signals into
    the same twisted pair will allow cross talk coupling. Since
    you are using G320 drivers which have single ended
    inputs and make no mention was made of converters, the
    logical assumption is that you are using encoders with single
    ended outputs.
    The power and ground leads are intended to have a constant
    voltage all the time and will couple less noise into the a
    phase signal than would the opposite phase signal which is
    a changing voltage signal.
    When using an encoder with single ended outputs connected
    through a cable with two shielded twisted pairs, I would
    recommend the following:
    Put phase A and Encoder Ground together in one twisted pair. I would
    use Green for Ground and White for phase A.
    Put phase B and Encoder +5V in the other twisted pair. I would use
    Red for +5V and Black for phase B.
    Connect the shields to ground (the negative supply for the
    encoder) at the G320 end of the cable. Do not connect
    the shield to anything at the encoder end of the cable.
    This provides shielding, but prevents current from flowing
    in the shield itself. Current flowing in the shield would
    couple noise into the signal via a transformer-like action.
    It is also important that the +5V and Ground have a filter capacitor
    at or inside the encoder. Some HEDS encoders lack this capacitor.
    See this Geckodrive application note if using HEDS encoders:
    http://www.geckodrive.com/ark-2/supp...?pid=91&id=101
    If you are using G320X drivers, you should also see the instruction
    manual regarding the setting of DIP switch 6 for HEDS encoders.
    Regards,
    Steve Stallings
    www.PMDX.com
    Apr 2004
    136
    encoder wiring
    .... well my attempt to provide a link to the Geckodrive
    application note about using HEDS encoders failed
    because the web site uses dynamic links. To get to
    the application note, go the www.Geckodrive.com
    home page and use the following clicks to navigate:
    >Support (on the selection bar at the top of the home page)
    >Application Notes (from the vertical column of selections on the left side)
    >Servo Drives (which appears below Applications Notes after you click there)
    >Using HEDS Encoders (which appears below Servo Drives after you click there)
    Regards,
    Steve Stallings
    www.PMDX.com
  1. The Best CNC Videos At IT Channel
    By bin95 in forum Videos
    Last Post: 09-12-2010, 12:38 PM
  2. I/O Channel Parameters
    By Probe Guy in forum Fanuc
    Last Post: 11-06-2008, 08:33 AM
  3. What bit to use to drill C channel?
    By teamtexas in forum Uncategorised MetalWorking Machines
    Last Post: 11-03-2007, 05:58 PM
  4. Looking for cheap encoder with index channel
    By JasonCampbell in forum Servo Motors / Drives
    Last Post: 09-13-2007, 03:31 AM
  5. IRC channel for EMC
    By Dan Falck in forum LinuxCNC (formerly EMC2)
    Last Post: 12-18-2004, 06:03 PM
