587,753 active members*
3,016 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Series Limit Switches with Shielded Wire
    42
    I understand that when wiring a limit switch using shielded wire the shield should be tied to ground at the controller/BOB end only. My question is that when you wire the switches in series, do you tie the shields together from one switch to the next until you reach the final switch?
    Wolfspaw
    24220
    Yes.
    Al.
    Albert E.
    42
    Thanks, Al.
    Wolfspaw
  1. How to wire my limit switches
    By Eddieman in forum Open Source CNC Machine Designs
    Last Post: 10-28-2011, 04:05 PM
  2. How did you wire your Mesa 7i37 Limit Switches??
    By torinwalker in forum LinuxCNC (formerly EMC2)
    Last Post: 03-08-2011, 02:20 AM
  3. Bridgeport Series II Interact 2 EMC retrofit -- limit switches
    By ichudov in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2010, 01:15 AM
  4. How to wire E-Stop Buttons and Limit Switches which Pin in Printer Port
    By guy2b1 in forum CNC Machine Related Electronics
    Last Post: 06-09-2009, 01:36 PM
  5. How to wire three limit switches
    By bgolash in forum CNC Machine Related Electronics
    Last Post: 02-16-2006, 07:38 PM
