603,893 active members*
3,888 visitors online*
Results 1 to 20 of 20
    May 2006
    168
    DIY DRO (digital read out)
    A while back I bought a mill. See link for mill pictures:http://www.cnczone.com/forums/bridge...rigid_ram.html.
    Since it had encoders attached to the steppers I decided to try and make a DRO. I still need to make a box to put it in.....nothing fancy just a zero function at this time. However I did leave the serial pins open so I can add functions if I decide to later. The main chip is the Atmega328 ( same as the Arduino). The chip is actually programmed with the Arduino Uno. I attached the current code in a text file.
    Attached Thumbnails Attached Thumbnails IMG_0211.JPG   IMG_0220.JPG   IMG_0224.JPG
    Attached Files Attached Files
    May 2006
    168
    put it in a box
    put it in a box and mounted it to the mill....
    Mar 2009
    144
    Very nicely done.
    Dec 2005
    112
    Excellent job. What's the resolution of your encoders. And till what speed can you read the encoders without losing any pulses. I am beginning to explore arduino for my cnc projects, specially it's interaction with Mach3. Right now I'm just a novice with arduino and yet to make a useful app with it.
    Zafar
    May 2006
    168
    Quote Originally Posted by zafarsalam View Post
    Zafar
    Thanks!
    I am running the 500 cpr at 4x so I get 2000 ticks per revolution. the mill is 5 tpi, so I get 0.0001" per tick. Max speed is 120 IPM. If I did the math right that means a tick every 50 microseconds (20 kHz). The interrupt for the micro-controller takes less than 10 microseconds...probably about 5 microseconds. I would guess that you could get up to 50 kHz without to much trouble.
    Dec 2005
    112
    Quote Originally Posted by rlwoodjr View Post
    Thanks!
    Is it Turbocnc on your machine PC?
    May 2006
    168
    Yes it is. Boots in a few seconds...
    Dec 2005
    112
    Last time I used Turbocnc, it was losing position on arcs and didn't have constant velocity contouring. Then I switched over to Mach3. That was almost 6 years ago.
    May 2006
    168
    That is too funny. I do not have any problems with arcs, but the constant velocity always sounded good...not so much for the mill, but I also have a router.
    I like DOS in the shop.
    Mar 2004
    1806
    Yeh, Dave K says he has CV working on V4.2. Now if we can just get him to release it!
    I use Turbocnc on my mill and router and soon (I hope lathe)!
    ditto the dos in the shop.
    Art
    AKA Country Bubba (Older Than Dirt)
    May 2006
    168
    Quote Originally Posted by Bubba View Post
    Dave has said that for awhile...any news on when it will be done?
    Mar 2004
    1806
    He hasn't said lately, had some correspondence Christmas time but nothing on that subject.
    Wrote wishing a happy new year with a "nudge", but no response.
    Art
    Dec 2005
    112
    Mine was 4.0, I guess. Maybe the position loss was with backlash enabled. It was a known issue then. Anyways, I am happy with Mach. I've controlled a variety of machine tools with it like, mills, machining centers, turning centers, turret punch, pipe bender, oxy-fuel cutter etc. Yet to do a router though.
    Jan 2012
    4
    Pretty impressive
    This is pretty cool. I started working on a similar project, although I intend to convert mine into a rdiculous overkill that can interpret eithe G-Code or Excellon files (my mill isn't CNCd yet).
    Do you have any plans to add more features?
    What LED drivers did you use? (MAX72xx or something else?)
    Reagards
    Yuriy
    P.S. I will probably "opensource" my project on my blog, but I don't want to clutter the forum with the URLs yet
    May 2006
    168
    Quote Originally Posted by ycroosh View Post
    Reagards
    Yuriy
    Thanks, I have thought of making a complete gcode interpreter and step/direction generator, but I have to many projects....not enough time. This board has serial connection so it could me modified later.
    See attachments for the schematic and pcb layout, I originally had more resistors to limit the current to the led's, but since they are only on 1/6 of the time I had to remove them to get the display to brighten up. You can see I am using just the atmega to drive the lcds.
    Jan 2012
    4
    Thanks for the details. It just dauned on me the that the axes don't need to talk to each other, so one MCU per axis works just fine . Is ATMega copind with the multiplexid pretty good? (i.e. no flickering)
    Thank you
    Yuriy
    Feb 2010
    230
    Thanks for the uploads and a very interesting article. Since this is labeled as
    open source, would you be willing to post the g-code file for the PCB? It looks like a double layer board, is this true?
    Regards, Carl
    May 2006
    168
    Quote Originally Posted by eaglezsoar View Post
    Single side board with jumper wires on top. See attached gcode files. M for mill and D for drill.
    May 2006
    168
    Thank you
    Yuriy
    I adjusted the delay to optimize the look until you cannot see any flickering.
    Feb 2010
    230
    Thank you for the files! It is rare to find someone who will go out of their way to share with others. Thanks again!
    Regards, Carl
  1. Laser triangulation for digital read out???
    By jduke in forum Benchtop Machines
    Last Post: 04-11-2011, 09:11 PM
  2. Digital measurement with remote read out from ROCKLER
    By jjobezo in forum Calibration / Measurement
    Last Post: 09-19-2010, 11:45 PM
  3. A Digital read out ? on our BenchMills
    By Arich0908 in forum Benchtop Machines
    Last Post: 04-28-2010, 05:18 PM
  4. digital read out for classic South Bend Lathe
    By meats in forum Benchtop Machines
    Last Post: 07-28-2009, 10:36 PM
