587,812 active members*
2,979 visitors online*
Results 1 to 7 of 7
    Jul 2007
    378
    File import ?
    I was hoping someone with XR4/5 could import this IGS file and tell me if they have any issiues with the import. I the Cad/Cam I'm useing has a hard time reconizing the holes, it thinks it's made up separate arcs with different Radius.
    Thanks.
    Jul 2007
    378
    Opps!!
    Looks like you cant upload IGS files.
    May 2004
    4519
    ZIP it.
    Jul 2007
    378
    Thanks Guys.
    Attached Files Attached Files
    May 2004
    4519
    Looks like this:
    927
    Here it is in OneCNC XR4..(XR5 was the same)..the file only contains 27 faces..you would need 28 to include the back surface with holes cut thru it..
    Appears to be a bad export.
    Took 10 seconds to fix / add the missing surface.. The green one.
    Jul 2007
    378
    WOW, thanks for the screen shots.
    10 seconds to repair the model seems much more resonable to me then Cam system I'm using now.
  1. Import stp file in NX
    By blmmdes in forum UG NX
    Last Post: 09-11-2008, 03:40 AM
  2. import .SAT file
    By Tinmuk in forum Surfcam
    Last Post: 07-23-2007, 10:28 PM
  3. file import(again)
    By swarfmacdaddy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-12-2005, 01:57 PM
  4. file import
    Last Post: 06-07-2005, 08:01 AM
  5. file import
    By motomitch1 in forum OneCNC
    Last Post: 03-25-2005, 04:08 AM
