587,700 active members*
5,344 visitors online*
Page 1 of 2 12
Results 1 to 20 of 26
    Nov 2009
    34
    Retrofitting an Italian Lathe (DI PALO DPR5)
    Good morning community, i will show you what i'm doing...
    i have an old Lathe DI PALO and i decided to retrofit with a cnc system...
    i started with the project, and bought all the necessary to make that work:
    30 mm INA linear guide for the axis;
    20-05 THK balls screw with ballnut for short axes;
    25-05 balls screw with double ballnut THK for long axes;
    2 servomotors leadshine with relative servodriver 400w for the axis;
    1 servomotor MAB with DigitAx driver 1.5 KW for the spindle;
    all the necessary for the lubrification and to make it works.
    here you can see the first fothos of the lathe, with the project and the starting works...
    Attached Thumbnails Attached Thumbnails tornio assieme (Copia).jpg   tornio assieme1 (Copia).jpg   torretta ass2 (Copia).jpg   torretta esplosa (Copia).jpg
    Nov 2009
    34
    the works go on
    when i finished the paint i started with the solution you can see in the pictures for drill the original guide using the original carriage, in this way i had the perfect parallelism...
    after mount i used the instruments to regulated them, then assembly...
    Attached Thumbnails Attached Thumbnails 170320122185 (Copia).jpg   170320122186 (Copia).jpg   2012-04-20 13.09.42 (Copia).jpg   2012-04-20 13.09.31 (Copia).jpg
    Nov 2009
    34
    well, i made the new carriage for short axes and i mount the short guide on it with lubrification sistem and all the parts made by me
    Attached Thumbnails Attached Thumbnails 2012-04-14 17.15.15 (Copia).jpg   2012-05-08 12.07.16 (Copia).jpg   2012-05-08 14.41.00 (Copia).jpg   2012-05-08 12.09.10 (Copia).jpg
    Nov 2009
    34
    well, then i removed all the gear in the box of the spindle and i made the pulley and i prepare to mount the motor on the box, the one you see on the lathe is not the motor i will use, i just try with that
    Attached Thumbnails Attached Thumbnails 2012-04-20 17.35.05 (Copia).jpg   2012-04-19 16.47.01 (Copia).jpg   2012-04-19 16.47.27 (Copia).jpg   2012-05-29 14.28.46 (Copia).jpg
    Nov 2009
    34
    now i will show the automatic turret i'm building for my lathe.
    all it's made with C60 steel and 38ndc4 steel
    Attached Thumbnails Attached Thumbnails 2012-05-16 12.28.57 (Copia).jpg   2012-05-19 12.59.58 (Copia).jpg   2012-05-21 09.50.00 (Copia).jpg   2012-05-21 12.37.52 (Copia).jpg
    Nov 2009
    34
    more
    Attached Thumbnails Attached Thumbnails 2012-06-13 17.31.00 (Copia).jpg   2012-06-14 12.09.03 (Copia).jpg   2012-06-14 12.22.38 (Copia).jpg   2012-06-14 12.22.46 (Copia).jpg
    Nov 2009
    34
    more abaut the turret
    Attached Thumbnails Attached Thumbnails 2012-05-29 18.21.13 (Copia).jpg   2012-05-30 18.13.55 (Copia).jpg   2012-06-04 12.27.54 (Copia).jpg   2012-06-05 11.48.41 (Copia).jpg
    Nov 2009
    34
    other abaut the turret and here you can see how it looks like mounted on the lathe.
    anyway i will mount a 160mm chuk (the original is 250mm)
    Attached Thumbnails Attached Thumbnails 2012-06-25 11.58.45 (Copia).jpg   2012-06-28 18.11.30 (Copia).jpg   2012-06-30 11.42.59 (Copia).jpg   2012-07-02 19.38.40 (Copia).jpg
    Nov 2009
    34
    the last pictures abaut the tool post i made, i made the one for the tool as you can see, then i made some tool post with er25 cullet for the drills and some like weldom for interior tools.
    Here it's possible also to see the lock system i build for that...
    please let me know what you thins abaut!
    Attached Thumbnails Attached Thumbnails 2012-07-05 12.40.50 (Copia).jpg   2012-07-09 12.10.29 (Copia).jpg   2012-07-09 12.16.28 (Copia).jpg   2012-07-09 17.25.17 (Copia).jpg
    Apr 2009
    31
    Amazing!
    Please show us more.
    Nov 2009
    34
    thanks AndreasL, i will post pictures as soon i made!
    Jul 2012
    centerless grinding is very useful for the machinery purpose .its good because centerless grinding gives support to machine in the mid point and machine done work properly.
    Sep 2005
    1195
    Asso,
    Show me your lockscrew on your toolholder
    Nov 2009
    34
    asuratman,
    i turned a back side of the toolholder with a 60° conic side, then i made the drill you can see on the plate corrispective with the conic side.
    i also turned the screw as you can see in the photo with a 55° conic side, well when you lock the screw in the side you will block the toolholder in the desiderate position.
    Anyway i have an other screw in the back side of the toolholder
    Attached Thumbnails Attached Thumbnails 2012-07-09 18.07.46 (Copia).jpg   2012-07-09 18.06.16 (Copia).jpg
    Nov 2009
    34
    works is going on, i decided to make the lock system with a clutch moved by an air piston, i bought a 50mm diameter so i will have a 160kg at 8 atm.
    Attached Thumbnails Attached Thumbnails 2012-09-28 11.33.17 (Copia).jpg   2012-09-28 11.49.28 (Copia).jpg   2012-10-03 09.38.52 (Copia).jpg   2012-10-03 09.38.44 (Copia).jpg
    Apr 2006
    169
    well done
    May 2005
    3920
    Thanks for posting!
    You have a very interesting project here, please continue to update us as time goes on.
    Nov 2009
    34
    news, the clutch looks like a good idea, it works well, i tried tu turn the turret but it's very hard
    Attached Thumbnails Attached Thumbnails 2012-10-22 18.39.45 (Copia).jpg   2012-10-22 18.39.19 (Copia).jpg   2012-10-22 18.39.10 (Copia).jpg   2012-10-22 13.10.45 (Copia).jpg
    Mar 2004
    1306
    Nice collection of machines you have there.
    Regards,
    Mark
    Nov 2009
    34
    i finally got the servomotor for the axes, two AC servo Yaskawa 850W with 2 servodriver DigitAx 2,2Kw
    Attached Thumbnails Attached Thumbnails IMG-20130122-WA0001 (Copia).jpg   IMG-20130123-WA0005 (Copia).jpg
Page 1 of 2 12
  1. Old Italian Made CNC Lathe HELP
    By BillBert in forum Mini Lathe
    Last Post: 02-02-2018, 12:45 AM
  2. Retrofitting an Aniilan equipped lathe
    By jbeech in forum Controller & Computer Solutions
    Last Post: 05-30-2012, 09:57 PM
  3. EMC2 and lathe retrofitting.
    By GuntisK in forum LinuxCNC (formerly EMC2)
    Last Post: 03-30-2008, 09:08 PM
  4. retrofitting CNC lathe
    By prash in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2007, 08:55 AM
  5. Looking for CNC Lathe near Ithaca, NY or Palo Alto California
    By cornellouis in forum Mentors & Apprentice Locator
    Last Post: 11-29-2006, 03:40 AM
