603,795 active members*
2,948 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Doosan LYNX coolant plugs?
Results 1 to 6 of 6
Hybrid View
    Jul 2009
    86
    Question Doosan LYNX coolant plugs?
    Hello,
    I am having some trouble figuring out what kind of set screw is used to plug the coolant channels on the boring bar holders that shipped with our machine.
    It's a Lynx 220L
    Here are some pictures of what screw I am looking for:
    Thanks.
    Feb 2009
    6028
    Looks like a 1/4 npt.
    Jul 2009
    86
    Quote Originally Posted by underthetire View Post
    I wish it were so easy
    After taking some measurments the pitch is either 0.9mm or 28 TPI, they were too close to tell the difference.
    Closest thing I could find in the handbook was 1/8-28 BSP but I don't think it's quite right.
    The doosan book says it's "1/8-NPS" that doesn't really make sense to me, it's not a straight thread, they are definatly tapered.
    Feb 2009
    6028
    A 1/4npt is 28tpi and tapered...I'm sure it's the metric equiv, but I'm sure the 1/4npt will fit. Got a loc line kit laying around? Try threading it in.
    Jul 2009
    86
    I gave the loc line fitting a try but it's 1/8NPT not 1/4. It goes in about 1 full turn then jams. Also 1/8 NPT is 27tpi as I recall?
    The small end of the taper on the loc line measures 0.380"
    The small end of the taper on the factory plug measures 0.350"
    The 28TPI is probobly correct as it is extremely close to 0.9mm, just the diameter is wrong. Any ideas?
    Aug 2007
    20
    Our puma is 1/8 npt.
  1. Doosan 220 lynx issue...
    By enigma173 in forum Daewoo/Doosan
    Last Post: 06-25-2016, 11:52 AM
  2. live tooling doosan lynx 200
    By Jeremy.davis58 in forum Daewoo/Doosan
    Last Post: 10-03-2015, 09:14 PM
  3. Doosan lynx 220 LC made in china?
    By philrace34 in forum Daewoo/Doosan
    Last Post: 12-31-2010, 02:49 PM
  4. Doosan Lynx 220
    By Schljuutene in forum Daewoo/Doosan
    Last Post: 02-12-2010, 06:44 AM
  5. Doosan Infracore Lynx 220LM
    By HelicopterJohn in forum Daewoo/Doosan
    Last Post: 08-02-2009, 11:44 PM
