588,685 active members*
6,488 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Convert spline to arcs or lines
    Nov 2007
    330
    Hi Guys,
    Seem to be having grief with some laser cutting shops.
    After a recent heated discussion at my usual vendor I've been speaking with a couple of new laser cutting shops and they're having trouble with my DXF or DWG files.
    I am saving the solid model as either a DXF or DWG file, selecting version R12 and exporting splines as polylines (I knew already that they didn't want splines), but still they are saying their software can't handle polylines either.
    When I re-open the DXF file in Solidworks and create a part from it, and measure the polyline, some of the segments are less than 0.1mm in length. This is with the "annotation views" option selected. If I chose the "faces/loops/edges" the shortest lines are as small as 0.006mm.
    If I open the DXF or DWG file in SW DWGeditor then I can explode the polyline to just a series of lines. But with so many parts that will need this done it will take an age, and just wondered if there's any way to skip the polyline during the "save as DWG or DXF" and move straight to lines.
    Any/all help greatly appreciated.
    Cheers,
    Matt.
    May 2010
    10
    I understand your problem. Until we upgraded our laser software, we got very "unpredictable" results when a customer provided a CAD file with a spline entity. It was very difficult to explain to a designer and we too had "tough discussions". Our latest software version really does an excellent job. As a matter of fact, we can import the customer's raw CAD data (including splines) and then export the newly created laser file as a .dxf and it will actually convert the data to a series of tiny lines that very closely approximates the original data. There's hardly ever a reason to do this, but sometimes the profile may need to be edited "outside of SolidWorks" and this allows us to do that with ease! I'd be happy to convert a SolidWorks to CAD sample for you or quote cutting the part out-right.
    We're near Asheville, NC
    Give me a call if you'd like ATE 2 ATE 3 9 ATE too WON sicks zero
  1. software to convert spline curve to tangent arcs
    By foxfx in forum Uncategorised CAD Discussion
    Last Post: 05-08-2014, 02:31 PM
  2. rotating a large arc or spline to tangent on 2 arcs
    By beekeeper in forum Mastercam
    Last Post: 12-12-2011, 12:20 PM
  3. Incremental arcs and Break arcs into lines
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 09-16-2010, 04:55 PM
  4. Create Arc And Lines From A N-Spline
    By thebowman in forum Mastercam
    Last Post: 11-02-2009, 12:39 AM
  5. lines-arcs vs spline problem
    By metlcutr55 in forum Uncategorised CAM Discussion
    Last Post: 07-07-2006, 04:16 PM
