587,982 active members*
5,759 visitors online*
    Sep 2010
    Question Looking for a Chrome Welding Machine?
    Hi anyone,
    I m looking for a 304 quality chrome welding machine(not aluminyum welding machine). How can i find that machine?
    For example, we have a two chrome piece.And we want to weld(attach) that two chromes. Can anyone suppose us any machine like that.
    Best regards, Ali
    Jan 2011
    Do you chrome moly?
    Chrome is a coating that is plated onto the surface. If you want to join two chrome pieces by welding them, you first have to grind off the chrome in that area, then weld and then get the whole piece re-welded..
    If in fact you are talking about chrome moly, then a tig welder would be your best option.
    Hope that helps
    Jan 2010
    485
    304 is usually a term for a grade of stainless steel. Any DC tig welder can be used on stainless, with the correct filler rod.
    Sep 2010
    thanks for replies,
    @piwko4 , no it isnt chrome moly, it is a 0,60mm chrome letter.There is 0,60mm side chrome and 1mm chrome front. we making a 3d chrome letter.and we use solder. but solder is very expensive and taking time.
  1. CNC Welding Machine?
    By Kraig1 in forum Waterjet General Topics
    Last Post: 05-16-2012, 02:22 AM
  2. Welding up a CNC machine, can it be done?
    By Tommy B in forum Welding Brazing Soldering Sealing
    Last Post: 03-20-2011, 11:16 PM
  3. welding 6061 alum before chrome plating
    By theisfarm in forum Welding Brazing Soldering Sealing
    Last Post: 04-27-2010, 11:47 AM
  4. welding on machine
    By ebydrc in forum Uncategorised MetalWorking Machines
    Last Post: 01-30-2010, 06:03 PM
  5. Tig welding around your machine
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 09-24-2007, 02:40 PM
