Hello, I own a unimat db-200 and currently operating it as a mill.
I am having issues on milling aluminum on right angles.
I have tried the clamp to hold the aluminum block and it seems it does not hold the piece perpendicular. I have tried to make the spindle perpendicular to the clamp but again the next cut always is a bit deeper.
disappointed by the clamp I tried the milling table, which gave good accuracy.
But now I have only milled the two larger sides of the square aluminum block. Keeping the aluminum with the narrow sides facing the milling table seems difficult. The clamp would be a good solution if it would work ok.
What am I doing wrong? and how to mill the 4 narrow sides of the aluminum square block?
