603,785 active members*
17,705 visitors online*
    Feb 2013
    16
    Feed rate does not match motor velocity
    Got my CNC mill up and running and I'm just trying to master the Mach3 software. Just a question:
    How come the feed rate shows 6 inches per second in the DRO by default even though my max velocity is only ~70 inches per minute (~1.17 inches per second)? When I jog or run G00, the machine does not move at 6 inches/second.
    Thanks.
    35494
    The feedrate DRO is 6inches/minute, which Mach3 defaults to at startup.
    G00 moves are done at the velocity in the motor tuning screen.
    Feb 2013
    16
    Thanks for the reply. Can feed rate go above the maximum velocity? On a slightly related note, when should I use g0 instead of g1?
    35494
    You can set the feedrate higher than the velocity setting, but the axis will not exceed the velocity setting.
    G00 is typically used for rapid positioning moves, and G01 is used when cutting. G01 speeds are at the current feedrate settings, while G00 speed is the velocity setting.
  1. Motor Speed and Feed Rate
    By arudson in forum Mach Mill
    Last Post: 05-27-2012, 02:41 PM
  2. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  3. Mach3 with Taig Motor Feed Rate Problem
    By alt255 in forum Taig Mills / Lathes
    Last Post: 12-13-2006, 08:50 PM
