588,410 active members*
5,306 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Slotting in VM 6.0 NOT
    Dec 2011
    316
    Well I've managed to get most 2.5 d functions working well.
    However I can't get a simple slot operation to work IF the slot width is the same as the cutter diameter.
    For example if I spec a .250 cutter diameter and a .251 pocket it will function. Unfortunately this results in double the number of passes.
    Any suggestions?
    Thanks, John
    Jan 2004
    3154
    John - I use the engraving Mops for that scenario.
    I do the same thing for a single pass with a facemill/flycutter
    Draw a single line (region) down the center
    Just have to tweak the in/out to suit your fancy
    Super fast
    www.integratedmechanical.ca
    Dec 2011
    316
    DareBee
    Much appreciate the tip.
    Will check out today, its been driving me nuts.
    John
    Dec 2011
    316
    DareBee
    Amazing how simple it is if you know the trick.
    Thanks again.
    John
    Jan 2004
    3154
    :cheers:
  1. 3mm Slotting in Aluminum
    By vindennl48 in forum MetalWork Discussion
    Last Post: 08-12-2013, 03:11 PM
  2. slotting
    By moxy in forum EdgeCam
    Last Post: 06-24-2008, 04:10 PM
  3. slotting programme
    By davedoubleu in forum Haas Mills
    Last Post: 09-27-2007, 08:42 PM
  4. Slotting MDF
    By Me2 in forum Material Machining Solutions
    Last Post: 07-28-2007, 05:25 AM
  5. Slotting for CNC
    By Kavanthony in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2007, 10:20 AM
