603,945 active members*
4,947 visitors online*
Results 1 to 7 of 7
Hybrid View
Jim981 Noob Australian JGRO build 10-11-2013, 11:38 AM
jckstrthmghty You would've been ok to use... 10-11-2013, 04:09 PM
Jim981 Hey, the electronics was from... 10-12-2013, 08:31 PM
chrapladm Did you finish this build... 02-01-2014, 02:31 PM
qcard Hi, I've just started... 03-20-2014, 12:36 PM
qcard Re: Noob Australian JGRO build 06-16-2014, 01:26 AM
WJHildreth Re: Noob Australian JGRO build 07-03-2014, 10:13 PM
    May 2012
    Hey all. After about 2 years of wanting to do something, I have finally put saw blade to plywood and started a JGRO. I chose this design simply for the fact that with no extra software, I could look at and print dimensioned plans of the machine. also that it's simple and basic for me as a first time builder, and should provide me with required experience and a machine with which to build the next one. For my birthday last year, I nagged the wife into getting me a package of NEMA 23's,breakout board and power supply off of eBay. The intention was to set this up and test run the electronics first. Then our PC tower crashed, chewing a hard drive, and that was the end of that. Most things are done off of the iPad now.
    This year I had planned on getting some 3/4 ply to make a start with. The first price of $196.00 for bc grade blew me over so hard it took me a week to consider asking for a second price. Good old Bunnings had 19mm form ply on sale. Went to our local..... Out of stock, on order! But I consider plywood significantly stronger than plain 19mm Mdf, so I saved even more and am using 15mm ply. Still heaps of strength but I just have to check the measurements a few times, with the conversion from decimal imperial to metric, then adjusted to 15 thickness. Will still end up using 9 or 12mm for the base unit and cutting face.
    Anyway here are a few pics of the build so far. Will be mostly standard, adjusted to metric of course. I may try the anti backlash designas is, but am considering acme screw or similar for the 3 drives. I also want to put side walls on the x axis and put in supports in the intermediate areas of the unit to reduce flex.
    Any questions or assistance, inbox me or reply.
    Starting JGRO design.
    Nov 2007
    483
    You would've been ok to use MDF. The rails deflect far before challenging the rigidity of the mdf structure. If possible you will want to create supports for all the rails on all axis's. Which electronics kit did you buy from ebay? My impressions most are troublesome and not worth few $$ you save. Avoid allthread leadscrews if you can and try to source multi start acme unless you can live with 30ipm jogging speeds.
    I hope you enjoy you build as much as did with mine.
    May 2012
    Hey, the electronics was from a guy in Hong Kong called xories. Search cnc kit, and there's a really good chance most of them will be from him. It was a four axis board with NEMA 23's and power supply. Was so long ago, I can't even find anything on it in my emails anymore.
    I went the ply because of my experience with Mdf being very negative (doesn't like fluids, being cut or being tapped). I guarantee I could have saved a lot more with Mdf, but I have a shed the leeks a bit, and a seasonal rat problem, so I'm trying to avoid the long term problems with it.
    Feb 2013
    Did you finish this build yet?
    And how much did you pay for ply?
    Jun 2010
    Hi, I've just started building a JGRO in Aus as well. Have you made any more progress? What leadscrews have you gone with and where did you get them?
    Cheers,
    Tom
    Jun 2010
    Here is a quick blog post I wrote about my build progress: https://mechinations.wordpress.com/2...ro-cnc-router/
    Tom
    Mar 2006
    115
    The JGRO router is a fun machine to build and run. If it helps here is a link to my JGRO router build and upgrades I have made over time. Maybe you will find something useful there.
    JGRO CNC Router
    Keep us posted on your progress.
    Regards,
    Joe
  1. My Build - Joe's Kit - Australian
    By crocky in forum Joes CNC Model 2006
    Last Post: 04-20-2020, 10:20 PM
  2. Australian PRO4896-34 Build Log
    By nickpeters in forum Avid CNC
    Last Post: 06-23-2017, 01:55 AM
  3. pro4848 australian build
    By carter j in forum Avid CNC
    Last Post: 12-04-2013, 03:24 AM
  4. My JGRO build
    By Sieg in forum Commercial CNC Wood Routers
    Last Post: 10-31-2007, 02:36 PM
  5. Noob will pay $500 + material costs for a ready to go jgro style machine
    By midevilone in forum Commercial CNC Wood Routers
    Last Post: 01-14-2006, 02:47 AM
