Hi Guys, thanks in advance for all replies.
I have a new Milling Machine build I have started. Design is finished, just need to finalise what size ball screw I will use on the "Y" Axis. (I always call my LONG axis the "Y"... is this correct by the way)
Long axis is 1700 mm long overall. I have 2 choices for the screws.
1/ 16mm dia, 10mm pitch max allowed revolution 650 rpm
2/ 25 mm dia, 5mm pitch max allowed revolution 1400 rpm
The machine will mostly be used to bore holes in 20 mm Aluminium plate Drives are Geko with Nema 24 (large case nema23) 650 Oz motors
What screw would be best do you think given the 25mm screw is double nut and twice the cost at $500
Thanks again
