603,413 active members*
2,397 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > G-simple tool definition - pocket says tool is too big
    Sep 2014
    30
    I'm trying to cut a pocket with a diameter of 2" and using a 1/2" router bit that I have defined but when I try to cut the pocket, I get an error saying that the specified tool diameter is too large for this feature.
    any clues as to what I may be doing wrong?
    Jun 2008
    562
    Re: G-simple tool definition - pocket says tool is too big
    Did you forget the decimal point in the tool diameter?
    Sep 2014
    30
    Nope, just checked that again
    Interesting thing, It will define the pocket fine if I use auto tool select when composing the pocket, then I can go back and change to the tool I want. It seems to handle that just fine according to the tool path animation
  1. Tool definition in RhinoCAM
    By FoxCNC1 in forum Rhinocam
    Last Post: 04-06-2014, 12:18 AM
  2. Tool Definition & Verify
    By Andre' B in forum Mastercam
    Last Post: 03-14-2012, 06:16 PM
  3. Tool Holder Definition Files?
    By dkaustin in forum SprutCAM
    Last Post: 05-16-2010, 03:34 PM
  4. Dovetail Tool Definition?
    By rc30fan in forum EdgeCam
    Last Post: 10-05-2006, 07:54 PM
  5. Tool definition
    By David Da Costa in forum Mini Lathe
    Last Post: 07-04-2006, 04:48 PM
