588,173 active members*
4,545 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Feed per revolution and surface feet per minute.
    Jun 2014
    22
    I'm confused why both have to be input in the IPS screen when performing functions such as OD turn. For instance; If I decide I want .005" feed per revolution and am using 100 SPM, but then change to 200 SPM, wouldn't that change the feed per revolution? I'm sure I'm missing something here and appreciate any replies.
    Jul 2005
    12177
    Re: Feed per revolution and surface feet per minute.
    No.
    If you increase the surface speed you increase the rpm so the feed rate per minute increases but it is still the same feed per revolution.
    Jun 2014
    22
    Thanks Geof
  1. Fanuc 6T - no feed per minute
    By L98FIERO in forum Fanuc
    Last Post: 05-16-2013, 01:13 PM
  2. surface grinder table feed retrofit???
    By escowizard in forum Uncategorised MetalWorking Machines
    Last Post: 10-29-2008, 01:47 AM
  3. Replies: 11
    Last Post: 10-13-2007, 07:03 AM
  4. surface speed and feed rate calculator
    By derkiow in forum MetalWork Discussion
    Last Post: 06-05-2006, 01:33 AM
