603,848 active members*
3,455 visitors online*
    Mach3 + smoothstepper + PDMX-109
    I recently purchased a PMDX-109 for addtional outputs. Does anyone have any idea how to get this working with Mach3?
    In Mach3, I've got port 2 enabled. In ports&pins, I've got output signals #7-14 configured to use port #2, pin 2-9.
    I've got the PMDX-109 plugged into Port 2 on the Smoothstepper and on the PMDX-109, I have the jumper configured to 'enable by power on' which should allow me to test the relays on the board by setting the port hi or low.
    If I look at the SmoothStepper Device Monitoring window, I can see the ports active when I set the outputs to 'Active Low'.
    Any help would be appreciated!!!!
    Re: Mach3 + smoothstepper + PDMX-109
    Well, after a bit more digging, it appears that it doesn't matter if I have port 2 enabled in mach3 or not.
    I've confirmed that if I run a quick VB ActivateSignal(OUTPUT), I do see it very briefly reflected in the ESS Data Monitoring window. However, still no joy on the card itself.
    Never mind, I have it working!!!
  1. Smoothstepper and Mach3 ver R043.066
    By GerhardJ in forum SmoothStepper Motion Control
    Last Post: 03-24-2014, 12:09 AM
  2. SmoothStepper, Mach3, Win 7
    By jharvey407 in forum SmoothStepper Motion Control
    Last Post: 02-12-2013, 05:40 PM
  3. Problems with Mach3/SmoothStepper
    By JJDennon in forum LinuxCNC (formerly EMC2)
    Last Post: 04-26-2012, 03:31 PM
  4. Mach3 + SmoothStepper + G540 = No go
    By CarbonKevin in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2009, 12:09 AM
  5. SmoothStepper and Mach3 setup
    By jeffmorris in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2008, 09:09 PM
