587,833 active members*
3,307 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Lancer 1000 tech specs needed
Results 1 to 6 of 6
    Jun 2015
    42
    Hi guys,
    cannot find any technical specification on Lancer 1000 with Acramatic 2100. Can you help me? And if there are big difference in comparison with Sabre ? Need the following:
    Table dimensions and allowed weight,
    Spindle motor power with CAT (or BT) 40
    Spindle speed max
    Feedrate speed
    Dimensions (!!!),
    Weight (!!!)
    Will be very appreciate!!
    Feb 2011
    423
    Re: Cincinnati Lancer 1000 tech specs needed
    I think the Lancer's are Cat50
    Sep 2010
    1765
    What type motors, spindle, drives?
    Feb 2015
    If you send me the serial number of the control, I can let you know what manuals we have available on the Control.
    Dec 2006
    585
    Take a look.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Lancer Specification
    Units 1000
    Longitudinal (table X axis) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . mm 1020
    Cross (saddle Y axis) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . mm 762
    Vertical (spindle carrier Z axis) . . . . . . . . . . . . . . . . . . . . . . . . . . mm 770
    Range, spindle gauge line to work surface . . . . . . . . . minimum mm 225
    maximum mm 995
    Throat Depth . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . mm
    Spindle (Snout) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . diameter mm
    length mm
    Table X--Axis
    Work surface dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . length mm 1274
    width mm 765
    Load capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . kg 2000
    Spindle Carrier, Z--Axis
    AC Drive Motor (continuous rated) . . . . . . . . . . . . . . . (standard) kW 12.5
    Spindle speed range . . . . . . . . . . . . . . . . . . . . . . . . . . . (standard) rpm. 40--6000
    Number of speeds . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Programmable in 1 rpm increments
    Tool Holder Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . #50 ANSI/ASME B5.50--1985 std.
    #50 ISO 7388/1--1983(E) std.
    #50 DIN 69 871--1986 (part 1) std
    #50 BT40 MAS 403--1982 (option)
    Linear Axis Feedrates and Thrust
    Feedrates . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . X,Y,Z mm/min 3--15000
    Rapid traverse rate . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . X,Y,Z m/min 24
    Axis thrust (duty rated) . . . . . . . . . . . . . . . . . . . . . . . . . . . . X,Y kN 4
    Z kN 10
    Accuracies
    Uni--directional positioning Z axis over full travel mm 0.004
    Uni--directional positioning X and Y axis over full travel mm 0.003
    Uni--directional repeatability per linear axis over full travel mm 0.001
    Automatic Storage/Changer Unit
    Storage capacity . . . . . . . . . . . . . . . . . . . . . . . . . Number of tools 30
    Tool selection method . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Random by programmed tool
    station number or tool ID
    Tool and holder weight . . . . . . . . . . . . . . . . . . . . . . . . maximum kg 20
    Tool drum load (evenly spaced) . . . . . . . . . . . . . . . . . . maximum kg 300
    Tool length . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . maximum mm 400
    Tool diameter (adjacent stations full) . . . . . . . . . . . . . . . . . . . . . mm 125
    Tool diameter (adjacent stations empty) . . . . . . . . . . . . . . . . . . . mm 205
    Automatic tool change time (metal to metal) . . . . . . . . . . . . . . . s 7.0
    Sep 2010
    1765
    EXCELLENT Mike! Way to go!
  1. Cincinnati lancer 1250 power up
    By CMmetals in forum Cincinnati CNC
    Last Post: 10-09-2013, 03:35 AM
  2. Cincinnati Milacron Lancer 1000 manual needed
    By SQT18MS in forum Machinery Manuals / Brochures
    Last Post: 10-11-2012, 09:02 PM
  3. arrow/sabre/lancer Cincinnati spindle motor
    By mike_Kilroy in forum Cincinnati CNC
    Last Post: 04-07-2011, 01:26 PM
  4. arrow/sabre/lancer Cincinnati spindle motor
    By mike_Kilroy in forum Want To Buy...Need help!
    Last Post: 04-06-2011, 05:15 PM
  5. Cincinnati Arrow 500 and Lancer 1250 Program Storage
    By Chaz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2007, 03:10 PM
