587,181 active members*
3,873 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > LC 20 5000 control alarm #905
Results 1 to 7 of 7
    Mar 2005
    110
    We just got this used machine and a #905 oil filter alarm prevents us from powering up completely. We've changed the filter unit the pressure switch, and the lube pump and still get the alarm. We assumed that this alarm is related to the spindle oil unit, but since changing all we know what to change, could it be another filter somewhere?
    The stuff we changed came off of other running Okumas we have.
    Apr 2009
    1262
    Re: LC 20 5000 control alarm #905
    If you have not powered up before, are you sure you are phased correctly?
    Jan 2007
    599
    Quote Originally Posted by OkumaWiz View Post
    so true, could be all it is. Have banged my head into that before with an Okada.
    Mar 2005
    110
    Yes it is phased correctly and by luck we found the solution to the problem. The alarm actually comes from the air conditioning system for the hydraulic oil supply. The manuals leave a lot to be desired frankly.
    Since heat isn't an issue where we are and what we run. we just disconnected the sensor.
    Thanks for your replies. Another Okuma in the world is up and running parts again!
    Jan 2007
    599
    Quote Originally Posted by stude8 View Post
    Thats most likely a spindle cooler, how did you check rotation? Some of the coolers i have come across have phase rotation protection and thats what sets of an alarm when its wrong.
    Apr 2009
    1262
    So did you change the filter on the hydraulic unit?
    Just saying sensors are usually there for a reason. It's one thing if it is defective, another if it's working correctly and the real problem isn't being addressed...
    Best regards,
    Mar 2005
    110
    What we did was disconnected the fan behind this panel. We will diagnose it further to know if the fan is good or not. What is interesting is the 905 alarm has nothing to do with oil only that the reefer unit, when it works, cools the oil. Thanks again for the help.
  1. Replies: 8
    Last Post: 02-25-2020, 08:31 AM
  2. Retrofit Prolight 5000 (Benchman 5000) to run Mach
    By Impyman18 in forum Benchtop Machines
    Last Post: 07-10-2019, 04:12 AM
  3. OSP 5000 Alarm 201
    By cncatj in forum Okuma
    Last Post: 09-24-2014, 11:20 PM
  4. Anilam 5000 Motion Control Card Fault
    By Eighteenten in forum Controller Cards
    Last Post: 12-09-2010, 08:13 PM
  5. Replies: 15
    Last Post: 10-03-2008, 01:10 AM
