587,957 active members*
3,673 visitors online*
Results 1 to 6 of 6
    Jan 2006
    179
    Turret backlash - video included
    Does anyone have this issue with their turret? Everything still seems to go okay during part cycles, but I'm rather concerned about this backlash in the turret. Thoughts?
    https://youtu.be/twokYUI0tyI
    May 2015
    111
    Re: Turret backlash - video included
    In the back of the turret installation manual is instructions on how to correct this. I had to do it to mine.
    Direct Document and Software Download | Tormach Inc. providers of personal small CNC machines, CNC tooling, and many more CNC items.
    Good luck. I had to work with it a little to get the locking correct.
    May 2006
    143
    Mine does the same thing I assume its fine since when cutting the forces will push it one way. I get pretty good tolerances on the x too.
    May 2015
    111
    Mine would change based on how much I would take at a pass/cut. Once I adjusted it I have no backlash and the turret stays locked. It was a little time consuming but it is worth the time.
    Page 24 has the instructions.
    Attachment 310410
    Jun 2006
    3063
    Mine locks solid - when correctly adjusted you shouldn't be able to rock the turret even a little, even with a broom handle for added leverage.
    May 2006
    143
    Confirmed just totally re aligned and adjusted the turret lock sensor. It is rock solid now.
    Jesse
  1. Diagnose Stepper Motor Issue - with video link included
    By bmacliberty in forum Stepper Motors / Drives
    Last Post: 11-10-2015, 07:03 PM
  2. Replies: 2
    Last Post: 09-18-2015, 03:36 PM
  3. HORRID backlash (video)
    By nateman_doo in forum Benchtop Machines
    Last Post: 10-12-2011, 07:43 PM
  4. router making weird noises, video included
    By bandtank in forum DIY CNC Router Table Machines
    Last Post: 03-29-2011, 06:28 AM
  5. Is this normal? I included a Video
    By andycorleone in forum Open Source CNC Machine Designs
    Last Post: 11-05-2008, 03:09 PM
