603,929 active members*
3,097 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Trumatic 240 Bosch CC220 Control 'freezing'
Results 1 to 6 of 6
    Gentlemen,
    I have a small issue with my Trumatic's 240 BOSCH CC220 control.
    When I hit the CONTROL RESET softkey, the operating program freezes, and I'm unable to continue. Only option is to turn off main power completely, and Turn on again after a few moments.
    I have already tried reloading program from EEPROM & EPROM, but problem persists.
    Any idea on this issue will be great.
    Thanks!
    Thomas
    Re: Trumatic 240 Bosch CC220 Control 'freezing'
    Ok, I think I figured it out.
    It has to do with X12 terminal con Control Panel. Somehow the USB to RS232 adapter plugged on the PC used to transfer programs was messing with the control. (Keeping Port open perhaps?) Once we unplugged it, control went OK once again.
    I hope this info helps someone else in the future...
    Apr 2016
    10
    Which software do you use for transfer, do you also generate nc code on pc? Also which software do you use? We have trumpf tc240 and we still program manually.
    Poslano sa mog MI 5 koristeći Tapatalk
    For transfer we use NCLite by CAMDEN Software. We use Excel and Notepad to write programs.
    Lightbulb Re: Trumatic 240 Bosch CC220 Control 'freezing'
    We use SolidWorks and Autocad to draw , than top300 to convert to nc files (notepad or wordpad) and then transfer them via Trasnfer data thru rs232 port .
    Nov 2021
    12
    we can sell you a cad/cam for your machine
  1. bosch cc220, need help
    By geo.less in forum Polls
    Last Post: 06-23-2016, 11:56 AM
  2. need language file for bosch cc220 cnc control
    By adrenaLinas in forum Uncategorised MetalWorking Machines
    Last Post: 07-23-2014, 01:58 PM
  3. Bosch CC220 control
    By Qandbe in forum Uncategorised MetalWorking Machines
    Last Post: 02-12-2012, 09:51 AM
  4. Problem with BOSCH CC220!
    By laserino in forum MetalWork Discussion
    Last Post: 02-06-2011, 11:04 AM
