Can 4th axis be added to all the versions of mill?
thanks
Frank
thanks
Frank
Sure, why not.
A is on X, B is on Y and C is on Z iirc.
All depends on if you can fit it on you machine and if your PSU will have enough Amps to host another drive and if your BOB has free outputs.
Konstantin.
Only Pro or Expert.Will Express and Advantage versions of OneCnc XR2 do 4 axis or is it only Pro and Expert.
