603,383 active members*
3,623 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi TS15 Turret reset procedure
Page 1 of 2 12
Results 1 to 20 of 30
    Apr 2013
    24
    Hi All,
    * I have 1998 Hitachi Seiki TS15 with seicos sigma 21 control.* I recently had the timing belt in the turret start to fray and the belting was pulled from within the middle of the belt wrapping around the pulleys causing it to not index correctly and causing a turret index time out alarm.* I was able to clear the belting and get it working again without removing the whole turret disc and was able to continue using it while I waited for a new belt to come until it happened again for the same reason.* I removed the "tool turret disc"* and get the old belt off and replace it with a new belt.* However, the timing is now off when I index the turret so it wont clamp correctly.* I still have it apart.*
    I cannot find the correct procedure to reset the timing of the turret in my manuals.* Online it seems different models of hitachi seikis use different 3 button combinations and procedures to reset this.* I have seen that I may need to change the 1815 parameter possibly and something else K00.3?
    Does any one know the correct procedure on this lathe?* Any help would be greatly appreciated.
    Thank you
    Re: Hitachi TS15 Turret reset procedure
    Hello docdesigns,
    I have the same problem with these lathe, i know how to changue the parameter K00.3, do you have exactly the bit that need must changed?
    The button combinations are Stop Spindle, Select button and feed hold at the same time.
    Dec 2009
    559
    That is a keep relay - so you have to go to Keep Relay 00 and change bit 3 from a 0 to a 1. PM me if you need more help and I can send you a procedure on how to fix this
    John
    Quote Originally Posted by shas595 View Post
    John
    Can you send me the procedure please?
    [email protected]
    Thank you!
    Dec 2009
    559
    Sent - take a look and let me know how it works out
    John
    Dec 2018
    I need this procedure too, can anyone send it to me?
    Jan 2019
    I have the same issue. Can someone send me the procedure? Thanks
    Mar 2019
    6
    john can you send me the reset procedure?
    Dec 2009
    559
    Send me a PM with your email and I’ll send you you
    Mar 2019
    6
    have you received my pm?
    Mar 2019
    6
    if you can send me an email to [email protected]
    Dec 2009
    559
    Hello
    procedure sent! Take a look and let me know that it worked
    John
    Mar 2019
    6
    john I cant change parameter 1815. how can i do that?
    May 2016
    533
    Hi can you send it to me as well [email protected]
    Cheers
    Mar 2019
    6
    no mather what I do I can't change parameter 1015 from 2 to 4
    Mar 2019
    6
    Figured out, at the Set Button I have enabled parameter write and all worked good. Thank you John, I owe you a beer !! Machine up and running !
    May 2016
    533
    Hello
    John
    Hi can you send me the procedure as well please to [email protected]
    Cheers
    Dec 2009
    559
    Glad it worked for you! That PWE setting is hidden - glad you found it and are back to making chips!
    John
    Quote Originally Posted by arthugot View Post
    Dec 2009
    559
    Just sent it to you - let me know how it works out!
    John
    Quote Originally Posted by mbservice View Post
    Cheers
    Nov 2019
    Ht23j
    Hi John, It looks like you have a lot of knowledge of Hitachi-Seiki's. I have an HT23J. The tool unclamp/clamp piston hit the hydraulic tool release piston while the turret was indexing, & stopped the turret. I don’t know how to get it back to zero. Can you help me with the procedure to zero it?
    Its a Hitachi-Seiki HT23J with a Yasnak control.
    Thank you
    Mike
Page 1 of 2 12
  1. TS15 Turret Index Error After Power Cycle
    By alphaprecision in forum Hitachi Seikis
    Last Post: 02-02-2019, 11:37 AM
  2. Hitachi TS15 canned cycle alarm
    By docdesigns in forum Hitachi Seikis
    Last Post: 03-15-2017, 02:45 PM
  3. Tapping on a Hitachi Seiki TS15
    Last Post: 11-30-2016, 12:26 PM
  4. rROBOFIL 330F Reset procedure
    By shahrzad in forum CNC Machine Related Electronics
    Last Post: 10-16-2014, 11:25 AM
  5. Replies: 5
    Last Post: 09-13-2013, 05:03 PM
