588,672 active members*
6,371 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Jan 2018
    6
    Why dont Tialn Endmills last?
    Hello all,
    I have been trying to use high speed machining methods on a older vf2. the machine is good for 10,000 rpm, but I cant feed much more than 120 inches per minute without alot of jerk and stutter.
    I am cutting 48hrc H13, and I use HSM Advisor to get my speeds and feeds. Parameters follow
    Endmill, Garr 4 flute Squar Tialn 3/8" 1" Flute
    Speed 7000rpm
    feed 115 ipm
    step over 8%
    depth 1x.
    cut style : plunge into open through hole, dynamic mill paths mastercam. g187 p2 e.01
    I am cutting pockets and I only get about 20 minutes of tool life out of an endmill which is only 2 pockets. (pockets are 2"x1.5" x .750 deep) So, not a lot of material moved. and the tool is on the hot side of warm after a couple minutes cutting, so I think its rubbing.
    I think maybe I need to increase speed to activate the coating. 7000rpm is about 700sfm, but is that hot enough? I also think I should take a heavier cut, but I am feed limited at 120ipm, so should i increase stepover, to say 12%?
    I would love to hear how you guys would make this cut. How long would you guys expect this endmill to last in 48HRC material?
    Thanks!!
    Dec 2013
    5722
    Re: Why dont Tialn Endmills last?
    You might take a look at the Garr tech page for that end mill, looks like cutting speed should be in the range of 60-90 FPM. I think you're turning a bit fast. https://www.garrtool.com/doc/pdf/tec...ling_guide.pdf About half way down the page.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2018
    6
    That doesnt make any sense??? thats 600rpm, and no where close to turning on the coating.
    Dec 2013
    5722
    I get 917 RPM and 7 IPM. But I'll bet you could use 40% stepover
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2010
    4262
    7000 RPM at 115"/min?
    You are making the pocket by abrasion, not by cutting!!! Wildly out.
    Cheers
    Roger
    Jan 2018
    6
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    thats a .004 chip load which is much above what the manufacturer recommends. however maybe the stepover isnt high enough. can you tell me where you would run it?
    Quote Originally Posted by TechMonkey View Post
    rpm turns on the coating ??
    A standard end mill with a coating on it is still a standard end mill . It's no different than trying to drag race a lada against the big blocks , you can replace the gas with alcohol but your still racing a lada . Garr carbides are soft in my opinion and you need a better quality carbide that has a variable flute variable helix , robjack , gorilla mill etc . Either vibration is killing the end mill or there is enough heat being generated to cook the coating , or both
    Maybe try positing a video of what your trying to accomplish
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Jun 2010
    4262
    I would probably start around 2000 rpm and 100 mm/min. Your DOC of 1x is a bit heavy unless you have the power and rigidity.
    With an 8% stepover there is serious potential for a lot of rubbing without cutting unless you are climb milling. You should be climbing. With climb milling I would be looking at a stepover of maybe 20%.
    If Dertsap is right about the Garr carbide, that could also be a problem. I use carbide cutters from CarbideChiu on eBay, rated at HRC65 (not HRC55 or HRC45). They are not 'traditional Chinese' by any means: German or Swedish carbide stock I think. Quite expensive compared to the cheaper stuff on eBay. The difference is very noticeable.
    Cheers
    Roger
    Jun 2010
    4262
    Can't edit my posting. Mumble.
    Once you have reasonable cutting with suitable chips, then start to go up in speed. But watch the chips: don't let them get too small.
    Cheers
    Roger
    Sep 2012
    255
    Hello all,
    Speed 7000rpm
    feed 115 ipm
    step over 8%
    depth 1x.
    Thanks!!
    I am away from computer now and can't check your numbers.
    But why such high SFM?
    On my FSWizard i am getting much more reasonable
    430 SFM and 0.006 ipt feed
    Jan 2018
    6
    Quote Originally Posted by zero_divide View Post
    I have always thought that anything under 450 sfm or so was coolant territory. I base that only on my lathe days from when I tried to turn between 350-450 sfm. and it was all coolant and the tools lasted forever. getting upwards of 500 sfm and you would start to see tool degradation but more parts faster. I also saw other sources that run their Tialn endmills from 1200-1600 sfm, along with the appropriate feed of course.
    So my question then is, if you recommend 450sfm, then how do I get to the next step and get more out of the tool?
    HSM advisor with chip thinning and hsm checked, gives me 4057rpm(398sfm) at 56 ipm with an 8% step(climb).
    Increasing to 7000 takes the surface speed to 687sfm and 96ipm. I was running 115ipm to try and keep the chip load up.
    I'm really curious how some people get these tools up to 200+ipm. maybe they aren't doing it with anything this hard. (which i dont consider 48 to be all that hard. )
    Sep 2012
    255
    This is what you get with your tool (150% sfm and feedrate):
    Material: H13 Tool Steel 45-50 RC
    Tool: 0.500 in 4FL Carbide TiAlN HP/Roughing End Mill
    Speed: 540.0 f/min / 4127.4RPM
    Feed: 0.0059 in 0.0237in/rev 97.82 in/min
    Chip Thickness: 0.0036 in
    Reference Chip load: 0.0016 in
    Engagement: DOC=1.00 in WOC=0.05 in
    Effective Dia: 0.500 in
    Cross Section: 0.20 x Dia.
    Power: 7.3HP
    MRR: 4.89 in³
    Torque: 9.29 ft-lb
    Max Torque: 7.90 ft-lb
    Cutting Force: 445.9 lb
    Deflection: 0.0009 in
    The reason the tool lasts so little in your case is that SFM is too high and it burns the tool. I normally would not go over 150% from recommended especially on demanding materials.
    At the same time you can not push the feedrate too high because 48Rc is pretty hard. You will just chip the edges.
    To increase the productivity you need to increase the Depth of cut and the number of flutes.
    Absolutely same conditions for a 7 flute endmill would yield 164.80 ipm
    Most manufacturers provide high-flute count endmills for hard milling for this very reason.
    Also for this very reason people try to avoid roughing a lot of hardened material.
    I used to machine a lot of 45-50 Rc hardox plates and they would eat cutters in a matter an hour. So the strategy was to try to get as much work done withing that time frame.
    Attachment 385184
    http://zero-divide.net
    FSWizard:Advanced Feeds and Speeds Calculator
    Jun 2010
    4262
    Power: 7.3 HP
    Just so!
    I suggest HSM makes a lot more sense on cast aluminium.
    Cheers
    Roger
    Sep 2012
    255
    Power: 7.3 HP
    Just so!
    Cheers
    Roger
    What do you expect ? This is not a Tormach-level material.
    And it is the opposite. HSM makes a lot more sense with tough and hard materials than with soft ones:
    https://www.emastercam.com/forums/to...r-hsm-request/
    Jun 2010
    4262
    Oh my, frightening stuff!
    I don't have that sort of power in my spindle, and see no need for my sort of interests.
    But fascinating all the same (in an Addams Family way?).
    Cheers
    Roger
    Jun 2010
    4262
    Mastercan URL
    Cheers
    Roger
    Jan 2018
    6
    Thanks for that info. My tool was a 3/8 but I get your point nonetheless. So I guess when your talking about the critical surface speed of tialn coated tools (ie, the point when the coating is activated and working) I guess what it boils down to is that it just happens at a lower speed in hardened h13 than in some other materials.
    I would like to present this video, in which robbjack is running 700sfm on a 1/2" 7 flute tool. with a 5-10% step over. Note at the end of the video, the tool is not hot. This material is 6 rockwell points higher than my material. He is running this tool at 125ipm. (So my chipload was quite a bit higher, and a bit lower in surface speed.)
    https://www.youtube.com/watch?v=JATjRSzXgjw
    This could very well be a much better tool than what I am using though.
    Sep 2012
    255
    There are several reasons why they are able to cut such hard material so "fast"
    1) they are using AlTiN coating that is harder than TiAlN and more temperature-resillient.
    2) Because of the toolpath configuration they are onpy cutting 20% of the time or so. Rest of the time tool spends cutting air and cooling.
    3) I do not know if it is really h13 56Rc and Have no idea how long it will last any way.
    Calculator can not give ideal parameters outright.
    It is supposed to land you in a comfortable zone at about 75%-100% of the available capacity.
    Jun 2010
    4262
    And don't forget - he is using a trochoidal cutting path too (as zero has pointed out). That is a lot different from a straight plowing.
    Hum - seems to be a bit of a glow from the tool though - fun stuff.
    Cheers
    Roger
    Jan 2018
    6
    Cheers
    Roger
    As I mentioned in the first post. I was using the same strategy.
Page 1 of 2 12
  1. SFM capability of Tialn
    By GITRDUN in forum MetalWork Discussion
    Last Post: 09-26-2015, 01:02 PM
  2. Tialn coated carbide vs non
    Last Post: 08-12-2015, 05:08 PM
  3. TIalN 1/4" ballmills??? where to buy?
    By mc-motorsports in forum CNC Tooling
    Last Post: 05-07-2010, 05:32 AM
  4. Tialn coated vs. uncoated?
    By Driftwood in forum MetalWork Discussion
    Last Post: 01-05-2009, 02:57 AM
