603,810 active members*
3,269 visitors online*
    Z Axis problem
    Hi -
    In my gcode I have the following
    F50
    G1 Z5.0
    G1 Z0.0
    Then continues with more junk......
    When it starts it goes to +5 and never takes Z down to ZERO. If I put -5 it goes to -5 and not ZERO. If I put 0.001 it goes to 4.XX9 or something... Not ZERO.
    Anyone here have any ideas I can try or what to do? Thanks KH
    Please check out my CNC blog
    http://cncinside.com
    4826
    Are you running in incremental (G91) mode or absolute (G90) mode?
    I got a reply from Art - he said use G90 and seems to be ok now. Thanks
  1. Boss 6 Axis Problem
    By DaveinUK in forum Bridgeport / Hardinge Mills
    Last Post: 02-21-2007, 05:06 PM
  2. Problem with Z axis
    By MagTDK in forum DIY CNC Router Table Machines
    Last Post: 11-01-2006, 03:12 AM
  3. z axis problem
    By UMASSREHAB in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-29-2006, 11:45 PM
  4. Z-axis problem
    By Trainhound in forum DNC Problems and Solutions
    Last Post: 12-14-2005, 09:24 PM
