588,152 active members*
4,392 visitors online*
Results 1 to 11 of 11
    183
    A Few Alum Plates Needed
    I need some parts machined from 3/8" & 1/2" Aluminum.
    1x_DrivePlate.SLDPRT 3/8" Alu 1 Piece
    2x_DrivePlate.SLDPRT 3/8" Alu 2 Piece
    3x_DrivePlate.SLDPRT 3/8" Alu 3 Piece
    2x_Bracket.SLDPRT 1/2" Alu 2 Piece
    Attached Files Attached Files
    Apr 2006
    50
    Have you tried Big Blue Saw ?
    Jul 2005
    80
    elogica. I cant read your files in this format. Can you post some cad files? If its 2D then dxf, if 3D how about STEP. I do a lot of aluminum work. Mike.
    Web site is conmach.com
    Apr 2006
    100
    quote sent by private message.
    mike
    [email protected]
    www.hessemachine.com
    Feb 2007
    15
    You have a P.M.
    Steve
    183
    Here are .step files of the parts +/- 0.1mm would be nice shipping max 7 days from po, need prices in by mid week
    Jul 2005
    80
    A couple of questions. Are the .201 and .125 diameter holes on the drive plates cearance holes? And are the 3 .201 holes that are .8 deep clearence holes or threaded. I got no call outs or dimensions with the step files and I know it should be obvious but I just want to make sure. Mike. conmach.com
    183
    Deadline is currently floating will draw up a set of dxf's this weekend.
    Chris
    Jun 2004
    60
    Sent you a PM.
    Trevor
    Oct 2006
    43
    dxf
    can you also send me dxfs and any other info. you may have i will quote asap.
    thank you
    Jun 2005
    1015
    i would also like some dxfs as i can't read solidworks parts.
  1. Milling Alum.
    By Smackre in forum MetalWork Discussion
    Last Post: 11-23-2006, 02:10 AM
  2. Alum Angle
    By Ursine in forum DIY CNC Router Table Machines
    Last Post: 05-13-2005, 12:49 PM
  3. vacuum plates
    By lelajoie in forum Uncategorised MetalWorking Machines
    Last Post: 09-28-2004, 11:00 PM
  4. RFQ - Two aluminum plates
    By kdoney in forum Employment Opportunity
    Last Post: 09-03-2004, 06:40 PM
  5. Vacuum plates
    By Raskins in forum DNC Problems and Solutions
    Last Post: 06-18-2004, 11:50 PM
