603,940 active members*
2,177 visitors online*
Hybrid View
XLR84x4 Servo size for this machine 06-06-2007, 11:34 AM
XLR84x4 The photo's I have taken are... 06-06-2007, 12:53 PM
XLR84x4 I have been busy reading lots... 06-08-2007, 07:11 AM
    May 2007
    26
    I am a definetly a newby to cnc tables and I purchased this at an auction today.
    It was a cutter used for cutting blinds and there is some solid engineering gone into this table. It has a vacum bed with stainless mesh. The vacuum table is split into 4 areas with valves controlling vacuum to each.
    Table size is 6 x 5.
    Electrically it is a bit of a mess with the controller board gutted and the servo's removed. Encoders are still attached.`The Z axis has a pneumatic 90deg actuator coupled with a plunge actuator.
    The plan is to cut fabric/carbon fibre/ fibreglass with this machine. I have a friend who is a specialists in lasers so ultimately we will fit one, but initially we will be installing a knife/blade
    My question is what size x and y servo's should we buy?? Brushed or brushless??
    I have been reading many post's and the Geoko seems to be a favored servo controller also.
    With the breakout box are there types that have solid state contacts out as well as servo controls as I imagine we will need to provide switching for the z axis actuators.
    Sorry about the picture quality it was extremely dark in the workshop and the slow shutter speed killed me.
    Thanks Jason
    Attached Thumbnails Attached Thumbnails Front end.jpg   Table end.jpg   Z axis.jpg
    May 2007
    26
    The photo's I have taken are shocking so I will try and get some better ones tomorrow.
    The x and y axis are belt driven is there a rule of thumb for gearing ratio's. I ask this as I will have to add a pinion gear to the servo shaft when I order the servo's
    Jason
    May 2007
    26
    I have been busy reading lots of posts about servo sizes.
    The control box has two transformers rate at 35V x 7.1A so I imagine the servo's
    would have been sized to 245W.
    The gantry weights about 60lbs at a guess and doing the sums like 60lb x 1000ipm/ 531 = 112W
    Is this a ball park figure or am I missing some thing??
    Jason
  1. Servo Motor Size?
    By schrupphobel72 in forum CNC Machine Related Electronics
    Last Post: 01-11-2007, 07:12 PM
  2. Moved:Servo/stepper size
    By dfstrasser in forum Vertical Mill, Lathe Project Log
    Last Post: 11-30-2006, 02:37 AM
  3. Servo size for this machine?
    By DennisCNC in forum Mechanical Calculations/Engineering Design
    Last Post: 04-19-2006, 02:24 PM
  4. Servo motor size question.
    By Fabric8r in forum Servo Motors / Drives
    Last Post: 10-29-2005, 08:48 AM
  5. How to figure out what servo size you need
    By replicapro in forum Servo Motors / Drives
    Last Post: 06-24-2004, 11:45 AM
