586,693 active members*
2,783 visitors online*
    Jan 2007
    626
    Coolant to mix with water for Fogbuster
    I usually use Kero in a squirter bottle when machining Aluminium, but since I bought a Fogbuster I have just been using water.
    I think I would get better results if I could find a water soluable coolant to use in the Fogbuster.
    Anybody know if anything available in Australia, that works well? I'd use kero if I could get it to dissolve in water...lol
    Steve
    Apr 2008
    82
    I think i've read a few guys use metho and water so its what i have just started using in a spray bottle and i'll use it when i get my cheap coolant mister up and running.
    Jan 2007
    626
    Re: Coolant to mix with water for Fogbuster
    Thanks Tiller, Does the Metho help with machining or just cooling?
    I sent an equiry to Unist Australia, but being so close to Xmas not replay yet....
    https://unist.com.au/solutions/metalworking-fluids/
    Had another look around their website and it appears that their 2210AL Coolant my be the ticket.
    Will see what they say.
    Jun 2010
    4256
    Metho is a known lubricant for machining aluminium.
    You may be advised to walk home rather than drive at the end of the day though!
    Me, I use 3 parts kero : 1 part olive oil in a pulsed MQL system, with air blast. Short pulses rather than a continuous stream. A small bottle of the mix lasts for AGES. And the oil is bio-compatible. The kero evaporates away.
    Cheers
  1. Water chiller - Tap Water vs Coolant Mix vs All Coolant
    By Montypaks in forum Laser Hardware
    Last Post: 07-08-2018, 01:17 PM
  2. Replies: 0
    Last Post: 11-05-2016, 09:59 AM
  3. Coolant for FogBuster?
    By JD2016 in forum Benchtop Machines
    Last Post: 10-04-2016, 01:09 AM
  4. Coolant for Fogbuster which is good for drilling Aluminum
    By X35 Design in forum Tormach Personal CNC Mill
    Last Post: 09-14-2014, 03:26 AM
  5. Coolant for fogbuster
    By David Da Costa in forum Benchtop Machines
    Last Post: 03-02-2010, 06:43 PM
