What type of coolant would you recommended for cutting aluminum in a FogBuster system?
Here is what FogBuster stated: "We use Hangsterfer's S-500 CF when working with aluminum and mild steel." "Cimcool's Cimstar 3890 works well with stainless steel." "Our customers have reported that Koolmist Formula 77 is also a good all around choice." "If cost is not a major concern, Acculube LB 2000 is an excellent plant based cutting oil that does not require mixing."
I have no experience with the aforementioned.
