603,855 active members*
3,943 visitors online*
Results 1 to 6 of 6
    Jan 2007
    61
    Haas Indexer Alarm
    Just got a new indexer for Haas vf-5 when we zero axis's in the morning every time it alarms out and says 168 A zero Margin too small?
    Jul 2005
    12177
    If it is new that should be a warranty fix.
    When the axis tries to find zero the motor drives it slowly until the limit switch is operated . Then the motor reverses and drives it slowly until the switch is released and as soon as the switch releases the controller starts looking for a zero position pulse from the encoder. What happens to cause the 168 alarm is that the pulse occurs quicker than the controller expects.
    Apr 2007
    178
    parameter 128 if it is a brushless unit the value should be -16384, zero or positive 16384 one of those 3 values should work. if it is a brush type unit then either -1000, 0, or 1000 should work. there is a way to do it in debug if you have newer software on the machine and the haas will figure out the grid offset by itself. but it is a little longer to explain if it one of those values does not work i will tell you how to do it in debug
    Jan 2007
    61
    Ok I will give it a shot will this affect my setup? Or should I wait untill I am done with these parts?
    Thank You
    Apr 2007
    178
    i would check my a axis offsets if you have any you want to zero return it quite a bit to make sure that the dist to go is repeating on the position page changing the grid offset does affect the zero position but not by much.
    Jan 2007
    61
    I put in 16384 and it worked great the A0. position in my offset did change.
    Thank you for the help
  1. Haas Indexer hrt610
    By binzer in forum Haas Mills
    Last Post: 06-07-2007, 04:30 PM
  2. hardinge / haas indexer parameter 30 ?
    By jim007 in forum Bridgeport / Hardinge Mills
    Last Post: 02-19-2007, 10:13 PM
  3. Haas S5C Indexer motor
    By Andrew M. in forum Haas Mills
    Last Post: 09-02-2006, 03:57 PM
  4. haas indexer serial protocol ?
    By pit202 in forum Haas Mills
    Last Post: 02-28-2006, 07:08 PM
  5. Haas indexer servo motor help.
    By Andrew M. in forum Servo Motors / Drives
    Last Post: 01-22-2006, 01:26 AM
