603,812 active members*
3,351 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Dumb Noob Question about Software and Glass Scoring
Results 1 to 6 of 6
    Nov 2016
    9
    I finally built my first machine - it's very basic, based off a Solsylva plan from years ago. Although I'd like to try making some parts very soon, one of the things I wanted to try first was to be able to score glass for some stuff I sell on the internet. Nothing fancy - just strips that are as close to parallel as I can get, and circles of different sizes, in bulk. I have a manual glass cutter that swivels 360 degrees, so I hope to mount this where most people mount the spindle. The controller I put together (kit) uses a parallel port. I don't have an older desktop with 32 bit Windows - I have either a Windows 10 laptop or desktop (64 bit only).
    I don't have any software yet and I can't justify spending much unless really necessary. Given that initially I just want to be able to score glass using either straight lines or circles, and given that I'm new to this and I don't know how to use any CAD/CAM software yet, and given that I probably won't ever need anything too complex, could anyone please recommend software to me? The only similar software I've used is Sketch-up which I'm guessing is not great for this? Any suggestions are appreciated. Thanks!
    Larry
    Apr 2004
    5950
    Re: Dumb Noob Question about Software and Glass Scoring
    That system isn't going to work, unless one of those computers has a working parallel port. So the first thing you need is an adapter that lets the computer communicate with the controller. There are several to choose from; the UC100 from cnc4pc.com and the Smoothstepper from Warp9td.com are popular around here. Then you'll need a control program that runs on your PC, like Mach3 or UCCNC. This turns the PC into a machine controller that can execute G-code; the commands that tell the machine how to move. For what you're talking about - just straight lines and circles, you probably don't need to use CAD/CAM;you can write the G-code by hand. Here's a basic guide to doing that: http://s3.cnccookbook.com/Downloads/...CodeCourse.pdf
    A diamond cutter in a spring-loaded mount will probably work better for you than a wheel-type cutter jammed in the spindle: Spring Loaded Engraving Tool Engraves Flat, Curved, And Uneven Surfaces With A CNC Machine
    Andrew Werby
    Website
    Nov 2016
    9
    Thanks for the info!
    Jan 2006
    738
    Another option for the machine controller is LinuxCNC which is open source (free) and works quite well. I have used it on 4 different machines over the years...
    Jan 2018
    1516
    Weighing it up, if not changing the PC I'd be drawn to using a UC400eth and UCCNC to control it.
    Nov 2013
    5408
    my preference and what I use is Mach4 and an Ethernet SmoothStepper.
    Having said that cheaper and simpler CNC software would be adequate for doing what you have described.
    You might even look at GRBL....cheap and cheerful.
    Craig
  1. Scoring stained glass
    By 3Eagles in forum DIY CNC Router Table Machines
    Last Post: 09-11-2024, 09:58 AM
  2. Dumb question from a total und utter NOOB
    By Travellinglee in forum Want To Buy...Need help!
    Last Post: 02-08-2017, 09:44 PM
  3. Glass scoring cnc wanted.
    By jarrick in forum Want To Buy...Need help!
    Last Post: 01-18-2015, 09:24 PM
  4. CNC Glass Scoring Machine Anyone?
    By LHC in forum DIY CNC Router Table Machines
    Last Post: 02-03-2011, 03:44 AM
  5. Breaking glass to a line by scoring it
    By Bob Shaw in forum Videos
    Last Post: 07-09-2010, 02:31 AM
