Hello
I have a 3.5kw 12a 380v China spindle and a VFD Sourctronic ST500 5.5kw 13a 400v(identical to the Powtran I500 VFD). The VFD is set up and Autotune can be started in vectoring mode. The problem I have now is that when I want to run the spindle in vectoring mode it makes noise. If I go and screw down the P-value, then I have to go from standard 30 to 12 until the noise is gone.In the attached PDF you can see the PID values ??for vectoring from register F5.00. My question now is how can I find out which PID settings are best here? With the milling machine I can not yet mill since the construction is not yet complete. actually the milling machine for the clamping plate should now be made.Sorry for the English, I translated it with google. I'm from Germany.
regards
Michael
