603,326 active members*
2,952 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Draw bar dismantle Okuma MB-500H-R
    Aug 2015
    36
    Hello,
    We've been asigned to change the coil springs in this horizontal machining center. As usual we started taking out the cylinder to pull out the draw bar assembly but It does not go through all the way, only slides few inches and one can feel the compression of the tired springs.
    Later we found in the parts manual that the collet prevents the draw bar free passage. Here is our trouble, the manual only mark that the collet is locked with a screw in the schematic but does not mention if It is left or right hand. We have tried both ways with no success.
    Our next step is dismantle all the back components to check if there is something else blocking the draw bar way out.
    Attached is the section of the manual that describes the spindle assembly. Hope you are familiar with this and can lend a hand.
    Greetings
    Ari Attachment 449946
    Enviado desde mi Redmi Note 3 mediante Tapatalk
    Aug 2015
    36
    Re: Draw bar dismantle Okuma MB-500H-R
    It turned out to be right threaded Bolt, but It was stuck with a lot of loctite. We had to use a 3/4" x 20" handle to loose It.
    After this everything went smooth, as usual.
  1. Replies: 1
    Last Post: 05-31-2022, 12:37 PM
  2. TORMACH 1100 DISMANTLE
    By keen in forum Tormach Personal CNC Mill
    Last Post: 09-13-2015, 10:03 PM
  3. OKUMA MC-500H Software!!
    By bbarber80 in forum Okuma
    Last Post: 06-05-2012, 01:00 PM
  4. MC-500H Okuma error
    By astral in forum Okuma
    Last Post: 03-23-2012, 07:53 AM
  5. New X4 Owner need help with dismantle the machine
    By bennetic in forum Syil Products
    Last Post: 02-18-2010, 02:24 AM
