588,578 active members*
11,760 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Sometimes spindle won't start, and ...
    Oct 2006
    68
    Question Sometimes spindle won't start, and ...
    if you turn the spindle over the "dead zone" manually, it runs, but you can hear the jitter noise.
    I've recorded a video showing the problems, and it is at http://www.deligeng.f2s.com/sx3.avi
    firstly, I suspected the motor had fault. However, I measured the sensor output and the coils later. It looked alright.
    So, should it be the motor drive board problem?
    4826
    Is this a single phase motor, or what kind of thing is it?
  1. Spindle will not start:HELP
    By raps in forum Fadal
    Last Post: 02-28-2007, 09:32 PM
  2. 6Mb 401 Alarm upon Spindle Start or Accelleration
    By Deltic_Engine in forum Fanuc
    Last Post: 01-17-2007, 08:44 PM
  3. Boss 5 series 1 BP, spindle wont start
    By signweld in forum Bridgeport / Hardinge Mills
    Last Post: 11-17-2006, 01:21 AM
  4. Help - Spindle Will Not Start from NC Control
    By CSE in forum Bridgeport / Hardinge Mills
    Last Post: 05-24-2006, 05:56 PM
  5. Spindle Start Time out
    By JonLed in forum Fanuc
    Last Post: 03-17-2006, 07:00 AM
