603,371 active members*
4,254 visitors online*
    May 2009
    1447
    Jerky Axis Moves on Curves
    I run Mach3 in my new 3 axis 4 motors table router cnc and for the first time I use ESS interface instead of the parallel port, my experience before has always been with the printer port. I run a NC code (has a lot of curved patterns and straight lines for testing the new machine) which I used back in 2018 and was working very good then but now it cuts straight lines perfect but when it hits curves the cuter moves in steps of about 1/8”, kind of jerky I would say. This code in the past used to cut the curves fast like straight lines.
    I tried different NC codes I have from the past and all are the same.
    I wonder if anyone knows what the problem is, perhaps since I’m new to ESS I missing some setting(S)
    Nicolas
    Jan 2018
    1516
    Re: Jerky Axis Moves on Curves
    Could incremental or exact stop be behaving differently!?.
    May 2009
    1447
    Thanks for the Help
    General Cinfig / Motion Mode was set to "Exact Stop". Changing this to "Constant Velocity" fixed my problem
    Nicolas
  1. Siemens 810M jerky servo moves
    By mlinkadelsol in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 01-30-2019, 02:06 PM
  2. Jerky Small Straight Line Moves
    By barchdesigns in forum Uncategorised CAM Discussion
    Last Post: 05-26-2016, 12:57 PM
  3. jerky moves
    By stoj in forum Videos
    Last Post: 10-22-2011, 06:33 PM
  4. Radial rapid moves around axis are jerky
    By surfsup in forum Fanuc
    Last Post: 09-13-2011, 08:39 PM
  5. Slow or Jerky G02 / G3 moves
    By ronateah in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2010, 11:35 PM
