587,338 active members*
3,430 visitors online*
IndustryArena Forum > CAD Software > Solidworks > ?! Please help me with this surface problem.
    Aug 2007
    5
    I'm still basically a beginner, but I know this shouldn't be...when I choose the two arcs for Direction 1 selections, the preview shows four very nice curvature combs how the surface will follow the contour of the arcs. But when I actually execute the boundary surface, it appears well below the arcs. What am I doing wrong?
    Jun 2003
    513
    In the Options menu, click on the Document Properties tab, go to Image Quality and at the top there is a slider that changes the shading resolution. This setting controls the visual properties of surfaces and bodies. There is nothing wrong with your surface, it is strictly visual and if you are working with large assemblies, models with large number of complex surfaces, etc... a graphics card that does not meet recommended requirements, then you may want to turn the slider down to minimize redraw time and decrease file size. You can change this setting anytime you want.
    Aug 2007
    5
    Hahaha!!!! :devious: Thanks!
  1. Surface finish problem
    By gar in forum Haas Mills
    Last Post: 05-22-2008, 03:01 PM
  2. Problem with surface rough...
    By JMFabrications in forum Mastercam
    Last Post: 09-13-2007, 08:29 PM
  3. Swept Surface problem
    By cijunet in forum Mastercam
    Last Post: 02-18-2007, 04:34 AM
  4. 3D Milling Surface Finish Problem
    By TurboME in forum MetalWork Discussion
    Last Post: 12-18-2006, 05:32 AM
  5. taft pierce surface grinder problem
    By metalhack in forum Uncategorised MetalWorking Machines
    Last Post: 11-29-2006, 09:19 PM
