603,899 active members*
2,139 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > want to add 4th axis to stepperworld fet3 board
Results 1 to 6 of 6
    Jan 2004
    85
    I bought a FET3/cruiser about a year ago (the fet4
    wasn't available yet) and I want to add a rotary table
    to my mill. I am running cncpro. How do I drive this
    extra axis do I have to add another paralell port? Thanks.
    Greg
    2139
    You don't Have to run another parallel port, but you would need to run jumpers or something from the unused Fet 3 pins to the new single axis board for step, dir, enable etc.
    Eric
    I wish it wouldn't crash.
    Jan 2004
    85
    Thanks Eric for the info. Now how do I do that as I am not an electronics wiz. Is there some info on the web somewhere? Thanks again!
    Greg
    2139
    I would ask Russ at stepperworld which pins are available and where they are located on the board. I don't have the board in front of me (I sold mine). I think russ has single axis boards as well.
    Eric
    Jan 2004
    85
    Eric,
    Russ said there was only 2 pins available for the extra drive and he said he doesn't have any 2 pin(step and direction) drives. I thought I could just wire them into the remaining pins in the parallel port as only 14 of the 25 pins are being used, am I missing something here. I'm sorry to keep bothering you and thanks for helping me.
    Greg
    Jan 2004
    85
    Here is what Russ wrote back to me: "It is possible that you could drive a forth motor by using the 2 aux output pins to interface with another driver. However, I don't have any single
    axis drives that use just step/direction interface (2-wire interface)"
  1. 4020 4th axis problems
    By little bubba in forum Fadal
    Last Post: 06-14-2005, 03:08 AM
  2. fet 3 15 amp 3 axis driver board (stepperworld)
    By mike10 in forum Stepper Motors / Drives
    Last Post: 04-30-2005, 04:30 AM
  3. 4th Axis
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 03-19-2005, 04:25 PM
  4. 4th axis controller board?
    By cncadmin in forum DeskCNC Controller Board
    Last Post: 08-30-2004, 09:38 PM
  5. 4th axis add on to a shop saber
    By dac in forum DIY CNC Router Table Machines
    Last Post: 08-23-2004, 03:58 AM
