603,383 active members*
3,324 visitors online*
    Jul 2019
    6
    PMX - DWG Conversion
    Hi:
    I am using Practicam software to produce parts for our plasma. It works well but it is only good for burning parts and there are times when I would like to punch the parts. I would like to be able to convert and transfer the drawing geometry to Striker software which is driving our turrets.
    My question is... How do I or can I convert PMX files which is the extension Practicam generates to either a DWG ( prefered ) which is what Striker generates or DXF which I can play with in CAD?
    I'm not a techy guy and none of our so called I.T. guys here seem to know or not care about putting some time in on this issue.
    If you could get back to me I appreciate it.
    We are using a MultiCam 1000 Plasma ( Hypertherm ) and Murata Wiedemann 2044 and 2044 EZ Turrets
    My direct gmail is [email protected].
    Thanks, Don
    Apr 2018
    162
    Re: PMX - DWG Conversion
    Are you sure that PractiCam doesn't have a DXF export capability? This suggests that it does:
    http://www.meta-lab.com/docs/PractiCAMPractiGuide.pdf
  1. dwg to stp file conversion!
    By PTdesigns in forum Uncategorised CAM Discussion
    Last Post: 06-16-2011, 09:10 PM
  2. SLDPRT to .dwg conversion!
    By Cmzwirner in forum Autodesk
    Last Post: 06-11-2009, 04:21 PM
  3. dwg file conversion
    By Hiredgun in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-17-2008, 02:08 PM
  4. Do me a favour ( DWG-DXF Conversion)
    By ynneb in forum G-Code Programing
    Last Post: 04-07-2005, 02:04 PM
  5. ASCII to .dwg conversion?
    By rc30fan in forum Uncategorised CAM Discussion
    Last Post: 03-31-2005, 11:16 PM
