603,314 active members*
3,325 visitors online*
IndustryArena Forum > MetalWorking Machines > Colchester Tornado lathes > Tornado 110 alarms: 437, 465, 7130, 1007
Results 1 to 6 of 6
    May 2023
    7
    Hello,
    I am receiving alarm messages on lathe Colchester tornado 110:
    made in 1997,
    GE Fanuc 21i-T
    437 X AXIS: CNV. OVERCURRENT POWER
    465 X AXIS: READ ID DATA FAILED
    437 Z AXIS: CNV. OVERCURRENT POWER
    465 Z AXIS: READ ID DATA FAILED
    7130 SPN 1 : OVERLOAD POW CIRCUIT
    These alarms occur on startup of lathe, before pressing green button which starts motors and hydraulic pump.
    I am also receiving:
    1007 SPINDLE SPEED MONITOR ALARM
    This occur at random times after lathe startup.
    Alarm existed before i got first 5 alarms.
    First 5 alarms occurred after i tried to get rid of alarm 1007, by procedure suggested on this thread:
    https://www.cnczone.com/forums/fanuc...t-problem.html
    1 switch off the main power
    2 in your spindle speed board there is 2 jumper
    Remove the first one from left and fix it on right
    3Press and hold on the black button. You can find it down the jumpers
    4 switch on tge main power
    5 the small monitor will show some numbers
    6 still holding on the black button till you see 3600 on the monitor
    7 remove your hand from the bottom
    8 you must be see one red led is on and of aging
    9 switch off the main power
    10 return the first jumper from the right to the left
    11 switch on the nain power
    12 you must see 3600 on your monitor
    Before i started procedure, machine was working fine with exception of 1007 alarm.
    Also i couldn't get over step number 6. Since holding button didn't do nothing.
    Also modules show alarms:
    Power supply module alarm 1,
    spindle amplifier module alarm 30,
    Servo amplifier module "-" (not ready)
    Not sure if these alarms are consequence of trying to get rid of 1007 alarm or something else, but timing matches perfectly.
    In the end even after following mentioned procedure alarm 1007 still occurs randomly after some time.
    The board (i assume that is used for spindle speed monitoring) shows numbers: 8080, and sometimes 8880.
    It also seems that LCD on board is having some glitches.
    Please for any information on or suggestion on how to solve this.
    Thank you, best regards
    May 2023
    7
    Re: Tornado 110 alarms: 437, 465, 7130, 1007
    Additional info: Emediately after machine is powered on, spindle amplifier module shows alarm 11, followed by alarm 15, after some time it shows alarm 30 as already described above.
    Hello, how did you manage to solve these alarms and what was the cause?
    I have alarm 437 and alarm 7130
    Thank you
    May 2023
    7
    Hello, I solved it by throwing all fanuc stuff out and did retrofit to mach4 I still have fanuc controller, PSU, servo unit, servos and some other boards if you need them.
    Apr 2025
    I am receiving alarm messages safety hold any help for this issue
    Thank you my router is multicam series 5000
    How you solved this alarm 7130 SPN 1 : OVERLOAD POW CIRCUIT?
    was the problem with the driver or the spindle motor?
    Thank you
    May 2016
    533
    Quote Originally Posted by Mradovanovic View Post
    Thank you
    Check your sero amp
  1. COLCHESTER TORNADO 80 alarm 1007
    By petkovm in forum Fanuc
    Last Post: 10-28-2023, 02:28 PM
  2. Seiki-Seicos LII Bubble memory Alarms --- Help on recovering from alarms 104,144,105
    By AZTEXAN_MIMXII in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2013, 08:59 PM
  3. Need Help alarm 1007
    By DanMatei in forum Fanuc
    Last Post: 08-09-2012, 08:48 AM
  4. Tornado 80 alarms out undersize bar
    By michael88 in forum Colchester Tornado lathes
    Last Post: 08-23-2008, 08:33 PM
  5. 2KVA 220 to 110 transformer. Can it be used with 110 volt primary? And gantry pic
    By Bloy2004 in forum CNC Machine Related Electronics
    Last Post: 06-29-2004, 02:28 PM
