603,314 active members*
2,467 visitors online*
    HPR Plasma hole burning
    I need help with fixing the lead in and lead out of the Hypertherm HPR260. please see attach pick of the hole, I have change the lead out to work close to a hole but it is still leaving a little of the burn out mark on the plate.
    not sure if the problem is from the lead in or the lead out. the current lead out for the hole in the picture is leadout 0.15; radius 0.03 angle 60. consumable is 260 on 5/8 plates. if anyone have a better quality holes please let me know how you set it. the HPR260 doesn't have True Hole technology.
    Thank You
    Re: HPR Plasma hole burning
    I use that plasma aswell. It support the quality hole transformation so you dont have to manually set leadins. It cuts perfect holes, always. As long as the hole is bigger than the thickness of the sheet.
  1. HPR 260XD
    By alfa2x2 in forum Hypertherm Plasma
    Last Post: 04-13-2018, 01:45 PM
  2. press fit bearing in plasma cut hole
    By johngalt47 in forum PlasmaCam
    Last Post: 06-09-2011, 05:01 AM
  3. Burning the perfect hole
    By sungaikantan in forum EDM Discussion General Topics
    Last Post: 02-11-2011, 07:09 PM
  4. is plasma cut the good cutting method for 2mm hole?
    By Arnaudb in forum Waterjet General Topics
    Last Post: 10-05-2009, 01:10 AM
  5. How small a hole can you plasma in 11 ga?
    By Stuff-Builder in forum Waterjet General Topics
    Last Post: 01-21-2008, 05:42 AM
