603,370 active members*
3,486 visitors online*
Thread: Reliability
    183
    Reliability
    Hi I'm currently having some issues with mach 3, first thing when i get in i power everything on, run mach3, home warmup spindle, set my 0 then start loading and cutting. Every other day this is fine today i've rebooted 10 times so far mach3 locks on loading gcode that i cut the previous day, all the job displays go blank, and it just sits on processing code... The I kept getting the error on dospincw....
    Anyone else have this issue, It's a great piece of software but i need to be in production every day.
    Apr 2006
    3498
    is that u using demo version 500lines limitation or paid one???
    35494
    You might want to try re-installing, and try the latest version if you are using an older one. Make sure to back up your .xml file.
    183
    Well it seems that if i don't run mach 3 the instant the desktop is up it's fine...
    Guess winblows is not quite fully loaded at that point.
  1. Reliability of commercial routers
    By cut more in forum Commercial CNC Wood Routers
    Last Post: 12-13-2007, 02:04 PM
