Hello. I have a CNC vertical machining center with Siemens 840D-SL. I'm trying to milling a thread with cycle70. Every thing is just fine except feed rate. I uploaded photo about the parameters.
I'm machining the thread with 4 passes. I set the feed rate as 1000mm/min but it changes every lateral stepover.
For 1000mm/min feed;
1st feed: 136
2nd feed: 173
3rd feed: 208
4th feed: 240
Is there anyway to fix feed rate?
This is my cycle command: MCALL CYCLE70(15,0,3,20,5,0.4,0,0.8,1,0.1,1000,0,0,0,0,1 1,1,,,,,0,1)
