603,899 active members*
3,293 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Advice Needed - DIY 3D Probe "Swingarm"
    Oct 2016
    191
    Hi all,
    I am looking to put a 3D probe on a swingarm that I can manually flick down for probing and up and out of the way when done. Probably an over-center mechanism with a spring.
    Why, you may ask? Well, I don't have an ATC spindle, just a lowly ER collet one so to get repeatable Z measurements, the probe would have to always be in the same spot when used. I do have a nice Metrol tool setter on the table but supposedly, touching the 3D probe off on the tool setter is bad practice and not consistent(?). Either way, it would likely be nicer to have it on an arm, that way it could also stay plugged in, I'd think.
    Anyhow, the only such thing I have seen is the Datron probe arm but I'd love to see or hear of any DIY examples or commercial ones if you have it and also any general advice on how would you would go about this? For now, I am thinking of machining it out of 7075, perhaps 10mm, and then use some bronze bushings for a nice tight fit.
    Oct 2016
    191
    Re: Advice Needed - DIY 3D Probe "Swingarm"
    No takers...? Would love to hear of someone who has done this and what to look out for
  1. Find Center Error "Probe Ignore, Activated at call for probe"
    By ngr1 in forum Mach Wizards, Macros, & Addons
    Last Post: 02-23-2020, 05:46 AM
  2. "Probe" and "Verify" not working - Mach3 & ESS
    By Mogal in forum SmoothStepper Motion Control
    Last Post: 03-17-2017, 07:05 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Mach Probe plug in what is "maximum z height for stuck probe" option do?
    By Rich05 in forum Digitizing and Laser Digitizing
    Last Post: 04-11-2009, 06:05 PM
  5. Need some advice on DIY 24"x24" CNC Router Table...
    By kanankeban in forum DIY CNC Router Table Machines
    Last Post: 06-01-2004, 12:38 PM
