603,378 active members*
3,119 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > FANUC ROBOCUT ALPHA. Setting positions after manual verticality adjustment
    i have followed the steps from the FANUC Robocut Alpha-iA series maintenance manual section 2.2.2 in order to square my head. Following the steps i have adjusted the verticality manually so that both lights of the jig appear on and off in MED 1. The issue I am having is setting the absolute position to U0 and V0. Currently i cannot thread wire as the machine thinks the head isn't square. The manual looks like it only refers to setting the absolute figures following automatic adjustment, these steps don't seem to be working the same for manual adjustment. Thank you in advance your help is much appreciated.
    Mar 2016
    364
    Re: FANUC ROBOCUT ALPHA. Setting positions after manual verticality adjustment
    Is the led on vert button on?
    If it isn't the vertical procedure is not finished properly.
  1. Replies: 8
    Last Post: 06-03-2025, 05:44 PM
  2. Fanuc Robocut alpha oc
    By BRAIN-HURTS in forum EDM Discussion General Topics
    Last Post: 12-16-2020, 12:03 PM
  3. Robocut Alpha OC Fanuc series 16-W
    By Lost-one in forum EDM Discussion General Topics
    Last Post: 07-24-2020, 02:52 PM
  4. Fanuc Robocut Alpha 0c error
    By Stefan89ss in forum EDM Discussion General Topics
    Last Post: 06-25-2020, 02:47 PM
  5. EDM Cutting Conditions For FANUC Robocut (alpha)-OC and (alpha)-OiA
    By aaronell in forum EDM Discussion General Topics
    Last Post: 11-02-2015, 07:01 PM
