603,348 active members*
2,788 visitors online*
    Feb 2008
    Which would you choose/avoid?
    I'm down to deciding between these two machines. I see some obvious differences, like routing area and that one has a slotted top. I also see differences in the motor sizes and the screw types. Is there anything that makes one of these clearly better or worse than the other or are they relatively similar machines?
    I'll be cutting/routing acrylic and wood.
    In advance... I appreciate your input. I've been reading this board for a few weeks, although just registering today, and it's clear that some people know this stuff better than I ever will. I'm not looking to flame either machine. I'm just asking why someone would consider one over the other.
    I've seen information on this board about this machine:
    http://circuitspecialists.com/prod.itml/icOid/9171
    I can't find too much at all about this machine, although I see quite a bit about the company and parts that it sells:
    http://www.kelinginc.net/CNCmachines.html
    Is there another machine that I should consider in this general price range?
    Nov 2007
    2466
  1. Avoid Teknic drives, they are cheap for a reason....
    By ckm in forum Servo Motors / Drives
    Last Post: 06-21-2016, 12:27 AM
  2. How to profile/contour and avoid areas?
    By Shepard in forum Mastercam
    Last Post: 12-04-2007, 12:11 AM
  3. Avoid Prosoftstore
    By gwb in forum MetalWork Discussion
    Last Post: 02-15-2007, 06:27 PM
  4. Router But hope to avoid surprises
    By watzmann in forum Community Club House
    Last Post: 04-19-2006, 02:10 PM
  5. How to avoid stinkin' coolant?
    By ESjaavik in forum DNC Problems and Solutions
    Last Post: 10-11-2005, 12:47 AM
