603,946 active members*
3,253 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > How can I coupling a stepper motor axis directly to other axis?
Hybrid View
meknik2001 How can I coupling a stepper... 05-05-2008, 03:40 PM
jhudler When you say axis, are your... 05-06-2008, 12:00 AM
meknik2001 Yes, you´re right. I´m... 05-06-2008, 09:39 AM
jhudler Your English is fine. To... 05-06-2008, 04:55 PM
hignog This is what i use. ... 05-08-2008, 07:54 PM
    Mar 2008
    6
    Question How can I coupling a stepper motor axis directly to other axis?
    Hello
    Basically, I need to know what kind of coupling are normally used to stepper motor axis.
    By the way... somebody knows how big can stepper motor axis be?
    Jun 2005
    334
    When you say axis, are your refering to the shaft size?
    What do you mean by; big? Size of the motor or the size of the shaft.
    Mar 2008
    6
    Yes, you´re right.
    I´m asking about stepper motor shaft. (When I posted, I didn´t know how to say "eje")
    Well... I´m thinking about design a Small CNC and my principal shaft (screw endless) has 30mm diameter.
    sorry for my English
    Jun 2005
    334
    To couple a stepper motor shaft to a lead screw, you use what is called a "Helical Beam Shaft Couplings" or something similar (with Zero Backlash).
    For example see: http://www.mcmaster.com/nav/enter.asp?pagenum=1147
    You do not want to use a rigid coupling. This would place unwanted stress on the motor from even the slightest misalignment.
    Size the coupler for the shaft sizes and the motor torque.
    Apr 2007
    26
    This is what i use.
    http://www.slidesandballscrews.com/f...ngs-p-141.html
    Quote Originally Posted by meknik2001 View Post
    Hello
  1. Z axis stepper motor
    By phidab in forum Syil Products
    Last Post: 04-11-2008, 01:12 AM
  2. bigger stepper motor for Z axis?
    By ZipSnipe in forum Benchtop Machines
    Last Post: 11-28-2007, 01:03 PM
  3. Z axis beam coupling help
    By Chamm128 in forum K2CNC
    Last Post: 06-05-2007, 10:38 AM
  4. 3 axis stepper motor drive
    By Paul V in forum Shopmaster/Shoptask
    Last Post: 02-24-2007, 09:34 PM
